BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Clunking low speed turns
      05-14-2020, 03:13 AM   #1
HooDat
31
Drives: e92 335xi 2008 | c63s amg 2019
So i took my front drive shaft off and the clunking at slow speeds when turning went away.. and there was a little play on the drive shafts u joint. I was wondering if there are any solid after market front drive shafts for XI, or should i just go with OEM? There's a few off-brands that are 1/4 the price of oem.
2008 | e92 | 335xi | 6MT | VRSF FMIC| VRSF DPs | VRSF CP | S&B DCI | FORGE DV | MHD Tune | BMW PE
2019 | w205 | C63s AMG
      05-15-2020, 08:25 AM   #2
matteblue3er
238
Drives: Racecar
Are you positive it's not CV joints? They may not click now since there is no load going to them, they are just rolling.
When the front axle CV joints wear enough, you get vibration only when accelerating
      05-16-2020, 02:43 AM   #3
HooDat
31
hmm i dont think it's the CV joints, i had both axles replaced recently because i heard a clicking/ticking sound and the boot was slightly ripped with leaking oil... could it be the front diff or transfercase?
      05-29-2020, 05:38 PM   #4
PhaseP
1007
Drives: 325XI
I bought a used oem when i hsd rrplaced mine. Check part number at realoem.com then search which model years use it.
      07-09-2020, 06:37 PM   #5
HooDat
31
Hmm so i had my Front driveshaft removed and the clunking at low speeds when turning went away... I replaced the TC fluid and cleaned out and regreased the TC Actuator (gears looked good) and reinstalled the front driveshaft. Expected the clunking/hopping to go away but it didnt. Does this mean my TC is going bad? i would imagine if the front driveshaft was going bad it would clunk regardless of turning or not? any help appreciated
