BMW M2 Forum > BMW M2 Discussions > Door misalignment
      05-10-2020, 11:39 PM   #1
walnuttea
39
Drives: 2016 BMW M235i, Alpine White
Door misalignment
Hey fellas,
Due to my extreme boredom during these crazy times, I've been doing a lot more work on the car myself. Surprisingly, after months of ownership I noticed that the driver side door is not perfectly aligned, as can be seen in the first 4 pictures. The door sticks out by maybe a millimeter near the door handle, and isn't perfectly aligned around the window trims. If you run your fingers along the door and the rear panel there's definitely an obvious difference. Likewise, the window trim is off by maybe 1 millimeter at the top and 0.5 millimeter at the base of the window. By comparison, I included a couple of pictures from the passenger side door where you can clearly see everything sits flush and perfectly aligned (last 2 pictures). Apologies for the dirt all over the car and for the orientation on the pictures (wash is pending once the weather is a bit more cooperative).
Frankly this does not bother be tremendously as it's hard to notice unless you're truly looking for it. I'm somewhat annoyed by it right now, but it'll likely pass as with most car imperfections over months and years of car ownership. I've also seen a few treads floating around highlighting similar issues with some X5 and 3-series BMWs. Haven't heard of this being an issue with the 2-series, and certainly not the M2.
Figured I'd drop by and, mainly out of curiosity, see if anyone else has noticed the same or run into the same issues? As far as I know this should be a quick alignment job at the dealership and will likely bring it up during my next visit for break fluid flush.
Cheers.
      05-11-2020, 12:10 AM   #2
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
I thought I was bad😂
I can definitely see what you're talking about though, and it's definitely one of those things you'll never unsee
I almost don't want to check mine hahah
hlm2c289.50
      05-11-2020, 10:11 AM   #3
hlm2c
Drives: M2C
Dam.. Time to junk it/part out now haha . All jokes aside, sometimes it pays to not look too closely for imperfections
      05-11-2020, 08:50 PM   #4
StarMan
Drives: 17' M2
Just checked mine, my doors are fine, but the top window trim is slightly off just like in one of your pictures.
      05-11-2020, 09:22 PM   #5
walnuttea
39
Haha appreciate the responses. It's definitely one of those classic "just leave it alone and move on with your life" moments. This lock down is taking us places we never expected
The door sticking out definitely bothers me a bit more than the window trim, but good news is that it operates normally and there are no seal or window issues. I'll still drop a note at the dealership but the break fluid flush won't be coming around until September so a ways away still.
      05-12-2020, 02:43 PM   #6
TrentMeister
2860
Drives: g82 comp
Not sure if it's the same with these cars, but on e36's you can loosen the frame half of the door latch and adjust to your hearts content. Give it a shot
Tags
alignment, door, misalignment
m2
