05-10-2020, 05:59 PM | #1 |
26
Rep 179
Got rear brake error with lots of pad left
Passenger Side: Driver Side: I sprayed cleaner on them, and checked the wiring, everything looks good. |
05-10-2020, 06:49 PM | #3 |
26
Rep 179
05-10-2020, 07:22 PM | #5 |
26
Rep 179
05-10-2020, 08:01 PM | #6 |
1781
Rep 4,456
05-10-2020, 08:59 PM | #7 |
26
Rep 179
05-10-2020, 09:04 PM | #8 |
8243
Rep 16,083
It appears that the inside pad on the passenger side is thin. That's the only place where the sensor will trip. My pads were improperly lubed at the factory, as a result the inner pads wore out twice as fast as the outers and I had to replace them at only 11,000 miles.
05-10-2020, 09:27 PM | #9 | |
26
Rep 179
05-10-2020, 10:07 PM | #10 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
Measure the pad when you get your new sensor.
05-11-2020, 05:30 PM | #13 |
480
Rep 681
It looks like a bit of uneven wear to me. The inner pad will trigger the sensor around there. Might want to consider changing your pads soon. Replacing the sensor will likely just trigger again since the pad is really close (seemingly already at) the recommend replacement depth.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
