05-09-2020, 11:53 PM | #2 |
4425
Rep 4,109
05-10-2020, 12:27 AM | #4 | |
4425
Rep 4,109
41psi on my tires turns my car into an E63S (sorry, AMG, but it's true)... and I don't mean that in a good way. |
Neptune71432.50 |
05-10-2020, 07:37 AM | #6 |
1408
Rep 868
Drives: M8 GC || M5 Comp || X7 40i
05-10-2020, 12:57 PM | #7 |
366
Rep 436
I do 35 all around
Superjackson122.00 |
05-11-2020, 09:19 PM | #10 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
35 all around and if they get too high when hot I set them to 35 hot (rather than cold).
05-11-2020, 11:10 PM | #11 |
857
Rep 703
Mine were at 36psi all around until the tire pressure set-point got fixed with the rear-view camera recall (it always recommended about 40psi, way too high!)
After the rear-view camera recall I now run 32psi cold all around (it recommends 33 usually when I start it up). PSI rises with temp - I'm usually around 35 or 36psi all around by the time tire temps rise above 70 degrees.
2023 M3: Isle of Man Green
2021 X7 40i: Phytonic Blue |
05-12-2020, 08:34 PM | #12 |
82
Rep 142
Didn’t want to start another thread. Are there AS or snow tires for the 20” oem wheels you recommend for winter or do you change wheels too?
05-13-2020, 12:46 AM | #13 |
377
Rep 541
It's next to impossible trying to find 275/35 and 285/35 20" winter tires. The BMW recommended winter wheels and tires (705M) are too pricey imo (don't see the point in spending that money on winters) so I got some 19" aftermarket rims and Michelin x-ice xi3 (245/45 square) gets the job done. The 245/45 footprint is very close to the summer tires' footprint so your speedometer won't be affected.
MDJAK82.00 |
05-13-2020, 05:33 AM | #15 |
155
Rep 317
i have been running the recommended pressure by the Idrive which is 3 bar (43 psi) which is way to high. now i run 2.7 bar (39) as recommended by the door jamb sticker and the car doesn't like it and throws the check tire pressure warning all the time, i wonder what will happen if i go with what you guys are running 34-35 psi. should i have 34- 35 with 20'' ?
05-13-2020, 10:17 AM | #17 | |
4425
Rep 4,109
05-13-2020, 11:55 AM | #18 |
155
Rep 317
i did that 3 times and after i shut off the car and start it again after a while i get check tire pressure notification again . but if i put it at 3 bar as the car advises it doesn't come on again
05-13-2020, 01:12 PM | #19 | |
4425
Rep 4,109
05-13-2020, 05:29 PM | #20 |
82
Rep 142
Appreciate the replies above re winter tires. Are there AS tires in the 20” size? I know tirerack doesn’t lost any. I did find some in another site but the load rating wasn’t the same. Not sure how much that matters if it’s close and I’m not loading up the vehicle.
05-14-2020, 03:21 AM | #21 |
155
Rep 317
05-14-2020, 06:33 AM | #22 |
35
Rep 135
