05-09-2020, 02:57 PM | #1 |
26
Rep 91
Alignment Issues, Front Camber
So just out in new set of wheels and had alignment done. For whatever reason front right camber is super off vs left camber.
I'm lowered on Bilstein B16's and they matched before. What would you is possibly causing miss match? And what's best way to fix it? |
05-14-2020, 01:05 PM | #2 |
Cheapskate
4450
Rep 4,993
Are you sure they were the same before lowering? And are the front springs seated properly? Typically it's due to one side being lower than the other.
05-14-2020, 01:56 PM | #3 |
26
Rep 91
Yeah, here's sheet from last year in January. Only thing that has changed since is new wheels. Was done at same shop too.
05-14-2020, 02:28 PM | #4 |
Cheapskate
4450
Rep 4,993
Doesn't really make sense. If you lowered it, you shouldn't have less camber than before. I'd check the front left coilover and make sure everything is seated properly. measure how high the fender is from the ground on both sides to make sure it's even.
