05-07-2020, 06:20 PM | #1 |
Rep 16
340mm M-sport dimpled and slotted rotors
Hey everyone. I have been searching all over trying to find an answer to this and nobody has anything definitive.
I have a 2013 335i with the stock M sport brakes. I purchased the M-performance rear brake setup (345mm/Red caliper/Dimple and slotted rotors) and am keeping the stock 340mm fronts. Has anyone found a 340mm dimple and slotted front rotor that comes close to matching the rear 345mm bmw rotors? |
05-07-2020, 06:28 PM | #2 |
27
Rep 93
05-08-2020, 12:23 AM | #3 | |
Rep 16
05-08-2020, 03:05 AM | #4 |
1781
Rep 4,456
05-08-2020, 11:47 AM | #5 |
890
Rep 1,703
Drives: 2014 428i and 2018 X5
Check out R1 Concepts. They've got what you need, and even offer a BimmerPost forum 30% discount. I just got four drilled rotors from them for $210
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
05-08-2020, 12:06 PM | #6 |
879
Rep 1,079
05-08-2020, 01:42 PM | #7 |
890
Rep 1,703
I've been buying rotors from R1 for over 10 years, on four different cars and I've never had an issue with quality.
thatBimmerBloke878.50 |
05-08-2020, 03:39 PM | #8 |
Rep 16
05-08-2020, 04:32 PM | #9 | |
890
Rep 1,703
r1concepts89.50 Honeypot685.00 |
05-20-2020, 02:46 PM | #11 |
Rep 27
Just installed these today. Zimmermann Formula F 2-piece 340mm rotors. I also have the 345mm set for the eventual rear upgrade.
2013 335i xdrive (pwg): BMW MPE, BMS Chargepipe, BMS Wheel Spacers 10/12, BM3 tune, M performance Calipers, Qi wireless charger, Bilstein B4 EDC suspension, Eibach Pro Springs + F80 bumpstops, Zimmermann Formula F rotors, Active Autowerke FMIC
thatBimmerBloke878.50 cfm56d7b5925.50 |
05-24-2020, 08:12 PM | #12 | |
Rep 16
I ended up ordering these. Identical to the 345mm upgraded performance rotors for the rear. |
KJ412.00 |
05-25-2020, 02:39 PM | #14 |
Rep 16
Been raining non-stop here in Dallas so I plan to have them installed during the week.
I will make sure to do a full write up going over my experience with them. I am pairing them with these Akebono pads, and I am curious if the ceramics will reduce the initial bite that I have been reading. https://www.fcpeuro.com/products/bmw...kebono-eur1880 If I do not like them I will switch them out for the Hawk 5.0s |
05-31-2020, 05:35 AM | #15 | |
207
Rep 603
The 340mm front rotor slotted/dimpled: https://www.realoem.com/bmw/en/partx...602&series=F30 just for the picture https://www.schmiedmann.com/en/produ...4-10-6-797-602
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
06-01-2020, 01:31 AM | #18 |
4541
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
06-01-2020, 07:36 PM | #19 |
Rep 16
Slightly, especially with the ceramic pads but I wanted the upgraded performance rears so I needed to match the fronts. It is something I am willing to deal with because the look is so good.
