05-07-2020, 04:57 PM | #1 |
Rep 13
Old gas in the car
Hi members,
Hope everyone is safe and healthy. I have 2018 BMW X3. I have not been driving my car much in the past 2 months, just 1-2 times a week for essential trips, so maybe just 2-3 km/week. I have not filled gas in past 2 months in the car. So, I probably have old gas in my car. I haven't put any fuel stabilizer in my car. My check engine light came on today, so I'm guessing that could be because of oxidation of gas in the car gas tank? So, In order to fix it, can I just fill the gas tank with new gas to the brim and add a fuel stabilizer in the car to fix the issue? Any help would be greatly appreciated. TIA |
05-07-2020, 06:05 PM | #2 |
625
Rep 706
If you've been driving it a few times a week, the issue isn't the gas.
Have you read the codes (CEL)? Find out what they are and stop guessing. Good luck! |
05-07-2020, 06:09 PM | #3 |
Rep 13
Thanks for your reply cooolone2.
Actually the check engine light also came on a month ago. I took my car for service that time and the code and problem which came up after checking was :- COMPLAINT: CHECK ENGINE LIGHT ON -- LIGHT HAS BEEN COMING ON/OFF INTERMITTENTLY -- CHK AND REPORT FINDINGS CAUSE: UPPER AIR FLAP DRIVE MALFUNCTION. CORRECTION: HOOKED UP BATTERY CHARGER AND ISTA, FOUND FC FOR UPPER AIR FLAP. PERFORMED TEST PLAN, TOLD TO REPLACE UPPER AIR FLAP CONTROL DRIVE. DIAG CODE D1150 00000000 40 009. REMOVED & REPLACED UPPER AIR FLAP DRIVE. CLEARED FAULTS. TESTED AGAIN, OK. So I don't think if this time its for the same reason. |
05-07-2020, 06:19 PM | #4 |
625
Rep 706
Don't think, don't guess... Get the codes read! Go from there.
Honestly, it doesn't mean the fix worked, or that was the original issue. But codes will guide the way. Worst thing people do is shotgun parts at a problem, thinking they know what the issue is. Is like having a health issue, get the right tests and diagnosis and then decide on what to do. Guessing and throwing things at your health may or may not work out well, lol. |
BMWZ41909.50 |
05-07-2020, 10:11 PM | #6 | |
Rep 13
05-07-2020, 10:12 PM | #7 |
Rep 13
05-08-2020, 08:49 AM | #9 |
6554
Rep 2,311
Drives: 9Y0 Cayenne S
Old gas is an urban myth.
The codes posted have nothing to do with gas. |
05-08-2020, 09:04 AM | #10 |
Rep 13
05-08-2020, 11:03 AM | #11 |
1910
Rep 5,105
Again, check the codes. Maybe you have an Evap valve fault and by removing the fuel cap to top up your fuel it cleared the CEL. Highly unlikely topping up with fresh fuel is the issue
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
05-08-2020, 12:54 PM | #12 | |
1394
Rep 2,221
Carburated engines suffer badly from stale fuel. The problem is the ethanol in the gas is hydroscopic and will absorb moisture over time causing gum deposits. This is more of an issue of you have lawn equipment - I had to replace my carburetor twice on my snow blower before I learned. Even when the gas is new it can have been sitting in the station tanks for a while (especially now). It's good practice to use stabilizer and run ethanol free fuel (available at home stores) if a carburated engine is going to sit longer than 30 days. Like I said, less of an issue with FI engines, but not a myth. https://www.autoblog.com/2008/03/31/does-gas-go-bad/ |
05-08-2020, 01:37 PM | #13 |
17314
Rep 18,737
Gas does not go stale in 2 months. Modern car fuel injection systems are designed to use ethanol content fuel. Just take the car out for an extended highway run, top off the tank and add Stabil to the fuel tank at a ratio of 1-ounce per 5 gallons of gasoline and drive home. The Stabil bottle has a built-in measurer. It doesn't need to be precise.
6ixSpd6014.50 |
05-08-2020, 01:42 PM | #14 | |
17314
Rep 18,737
Just replaced the carburator last weekend on my 20-year old Craftsman lawn mower. Runs like a champ now. |
05-08-2020, 01:59 PM | #15 | |
1394
Rep 2,221
I had an old bottle of Stabil and it turned into a gummy mess. Perhaps it would fair better when mixed, but I was a bit worried about it. I run the star tron in all the gas, but at the end of the season I run it dry and then run for a few minutes of True Fuel that they claim has an indefinite storage life. I haven't used my snow blower in years.. I'm not convinced that stale gas has zero impact on FI engines, but definitely not in 2 months. |
05-08-2020, 05:14 PM | #16 |
1910
Rep 5,105
When I had a 3rd vehicle that was stored during the winter I would top up (Shell V) and add fuel treatment and it sat covered in my garage for 5+ months. Zero issues come spring.
Efthreeoh17313.50 |
05-09-2020, 07:11 AM | #17 | |
17314
Rep 18,737
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
05-09-2020, 09:37 AM | #18 | |
1394
Rep 2,221
This way it removes all the old gas. Sorry to OP for the off topic posts |
