Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions BMW G20 Coding Door Handle LED's in Reverse
      05-07-2020, 06:05 AM   #1
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
Hi All
I am hoping to code door handle LED's or puddle lights in reverse on my newly purchased BMW G20. I coded this feature on my previous F32.
Anyone know if and how I can code this preferably with Bimmercode App or ESYS as a second option?
      05-08-2020, 06:03 AM   #2
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
I would love that to
      05-08-2020, 09:06 AM   #3
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Sounds like a pretty cool feature..
      05-19-2020, 12:10 PM   #4
andy5468
andy5468's Avatar
90
Anyone know if this is possible on the G20?
This was a cool feature that was able to be coded on the F30/F32.
Wouldn't mind coding this on my G20?
      05-22-2020, 04:17 PM   #5
A6bullet
Germany
337
Drives: 2020 330i Msport
Bump, interested as well
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      05-25-2020, 12:41 AM   #6
sddz6269
China
32
Drives: BMW G20 325i
Very interested!!!
      05-25-2020, 02:50 AM   #7
andy5468
andy5468's Avatar
90
Just received the following response from Stephan at Bimmercode on the door handle LED's in reverse for the G20 -
Hi,
This is not possible for the G20 unfortunately.
A6bullet337.00
      05-25-2020, 11:07 AM   #8
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
First of all, both my retired F30 and my current G20 came with reverse activated door LEDs activated (G20 has a checkbox in the exterior light section of car that I checked); I did, however, do some research to offer some assistance to getting this neat feature activated.
On my F30, the FEM_Body module had 3070 LCIMaster>OVT_BEI_RuekFahrLicht set to aktiv. I used this function to search all 7 CAFDs for BDC_Body since G20s do not have either FEM or REM modules, but rather just the BDC_BODY module. Unfortunately, I could not not find any function with this function (or parts of it name); so I tried using the English "DoorHandle" with the function set to aktiv since my car came with these active.
Here's what I found for my car, all in CAFD 7083:
3001 EnergyManager section:
* EM_TRAMode_0x20_DoorHandle_Inh set to aktiv
* EM_FEMMode_0x20_DoorHandle_Inh set to aktiv
Here's what I found for my car in HG_MGU (CAFD 3E52):
3000 HMI_Speech:
* Door_Handle_Light set to aktiv
I offer all of the above for someone to check out on their car if the reverse activated door handle lights are not activated. Would like to know if that works or not
Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
Appreciate 3
VipinLJ1941.50
A6bullet337.00
      05-25-2020, 04:51 PM   #9
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
RSnic Those are activated in my 330i too. But it doesn't turn on when I'm backing up unfortunately.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      05-25-2020, 05:59 PM   #10
RSnic
RSnic's Avatar
VipinLJ ,
Hmmmm, am running out of ideas, but a dumb question -- and I apologize up front. You do have LEDs in your car's door handles?
Al
Retired: 2014 328i
BMW CCA
      05-25-2020, 08:57 PM   #11
VipinLJ
Petrolhead
VipinLJ's Avatar
Originally Posted by RSnic View Post
VipinLJ ,
No dumb questions here and no need to apologise.
If you're talking about the lights on the door handles, then yes. I do have them. They light up when I unlock the car. They stay on for a bit. One day, I thought those lit up when I backed up because I could see them on through the ORVMs. But I had to back up a wee bit and they turned off after a bit while I was backing up.
Current:
      05-27-2020, 06:06 AM   #12
A6bullet
Germany
337
Damn I dont get it, why would this not be an option?
Using the 360 cameras at night is pointless unless theres light to see the surroundings.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      01-02-2021, 04:29 AM   #13
phayze
29
Drives: BMW
Anyone able to find any coding regard to this?
      10-14-2022, 07:46 AM   #14
latexyankee
13
Drives: G20 330i Msport
Bumping for visibility. I'd like to enable this as well.
      10-25-2022, 01:19 PM   #15
Assassin
142
Drives: M340d MHT xDrive
I sent a msg to Bimmercode asking if this could be done on G20...... answer was it can't.
G20 M340d X-Drive M Performance, Black Sapphire, HUD, Adaptive Susp...... previously
F31 335d Xdrive Shadow Edition M Performance, Individual Tanzanite Blue, HUD, Adaptive Susp, Evolve-R Map, Xhp Stage 3
E60 535d Msport Carbon Black/E39 530d MSport, Black Sapphire/E34 525i MSport, Avus Blue/E34 520i MSport, Briliant Red
g20
