05-06-2020, 01:52 PM | #1 |
Rep 7
2018 F30 320d M-Sport ZF8 Gearbox Issue After Engine Replacement
Changed an engine in the above vehicle due to aqua locked engine. Used same spec engine from same MY vehicle. Bolted original zf8 gearbox to it & reinstalled to vehicle. Engine starts & runs fine, but gearbox will not shift out of park. Vehicle recognises gears are trying to be selected, as it asks for brake pedal or select button on shifter to be depressed, but it will not shift from park. The lever on the side of the gearbox is closed so transmission is live. There are no warning lights on & having had fault codes read, nothing shows up? Any thoughts or manual work rounds to be had?
05-06-2020, 04:23 PM | #4 |
6431
Rep 8,504
My understanding is that the TCU and the ECU (as well as various other control units in the car) have to all be coded into the car.
The ECU and the TCU operate in a continuous feedback loop. It may be that the new engine and the transmission don't recognise each other.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
05-06-2020, 04:50 PM | #5 |
840
Rep 1,993
Drives: F30 335d
Agree, although if only replacing the engine you would leave the ecu as is. So it should still all work in harmony.
Tags |
2018, 320d msport, coding, ecu, zf8hp |
