My car had a bad weekend :(
09-17-2008, 05:22 PM | #1 |
150
Rep 409
First, I let a sober friend park my car in a garage... Silly, I know... But I was not able to drive intoxicated and my car needed to be moved. Apparently sober does not equal good driver... She scraped my car against a cement base column when she parked.
Next, I think a bicycle got too close and scratched the rear of my car. Do these scratches look too deep to be removed without repainting? They're pretty faint, you have to be looking for them to see them. |
09-17-2008, 05:33 PM | #3 | |
150
Rep 409
I took the car outside to see if the sunlight could catch the scratches a little better... |
09-17-2008, 05:48 PM | #4 |
No Member
8
Rep 428
Most of that will buff out, but you'll probably have to get a little paint where it went through to the bumper. I'd check out a paintless-dent-type place or 'cosmolision' or whatever they call it where you are. They're usually pretty cheap. I'd probably put that under $500, say $tree-fiddy or so.
09-17-2008, 06:01 PM | #6 | |
Rep 35
Most of that will come right off. I use a product called ScratchX from Meguiar's. Not as harsh as a rubbing compound. As far as the front where some of the paint has been scratched off, nothing a bit of touch up paint and wet 2000 grit sand paper won't hide. |
09-17-2008, 07:06 PM | #7 |
Doctor
32
Rep 634
Drives: RRSport, 335vert, 997 S, Sc430
Doh. Doesn't look too bad though... I know it will look perfect after you get it fixed.
2002 Lexus Sc430
2007 BMW 335i Convertible Space Gray on Coral Red 2007 Porsche Carrera S 2011 Range Rover Sport HSE Lux UCLA D.D.S. Columbia University Dental Specialist |
09-17-2008, 07:09 PM | #8 |
30
Rep 679
+1 on ScratchX, i tried rubbing compound before, very difficult to play with, must be really light, and you can't put any pressure when your using it otherwise you will cause more little scratches that you can see..i recommend getting a professional if you gonna wet sand, if you have no experience at all just get a pro, at least if they don't do a good job you can complain and hope for a better one, if you mess it up, it might be too late and even a pro can't fix
09-17-2008, 07:20 PM | #9 |
863
Rep 5,448
Back no prob - front you won't get it all out - some of it is through the paint, but you can make it look a lot better, and if you are really worried about it, find one of the airbrush guys that fixes chips and scratches and they will make it disappear - especially on TiAg - super easy to match and blend!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
09-17-2008, 10:42 PM | #10 |
34
Rep 836
BMS E92 335xi | PROcede | K&N | KW | VMR | LUX | Bastuck |
09-18-2008, 08:57 AM | #12 |
ahat
1036
Rep 2,592
Start with some 2K grit sandpaper and get it smoother. Then wash the area good and use some denatured alcohol to clean it. Wipe with a link free rag. Then spray a coat of primer or two and then use a can of spray touchup (not brush). Finally spray with a coat of clear. This process works for some of the deeper bumper scratches - yours might not need the entire process. Id start with just some brake cleaner spray and see how much it removes and then maybe some rubbing compound MEANT for plastics.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
09-18-2008, 09:35 AM | #14 |
66
Rep 2,189
bottom line... did you get any ???
ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
09-18-2008, 04:58 PM | #15 |
18
Rep 304
Drives: 2007 black sapphire coupe JB+
rule of thumb is if you can catch your fingernail in the scratch it will take more than just buffing.
09-18-2008, 05:22 PM | #16 |
Not looking 2 SPEED, just looking GOOD
45
Rep 2,516
Not that bad, just apply some scratch remover but the deap one that bares the primer needs a little touch up.
