05-06-2020, 10:44 AM | #1 |
Tanzanite
9
Rep 25
Drives: 2019 BMW 330i xdrive G20
Headlight switch button
Just curious if anyone has tried to take apart the headlight switch assembly? On my previous car I was able to take the switch apart an take off a small amount of plastic to have the button actually function.
05-06-2020, 11:24 AM | #2 |
932
Rep 4,323
Drives: M340
I am assuming you are referring to activating rear fog lights.
They completely changed the electronics on these switches and that mod is no longer applicable. I have purchased a Euro switch which also still doesn't activate the rear fogs. From the research I have done, G20's are no longer wired from the factory for the rear fogs even if you activate rear fogs via coding. We have been discussing it on this thread https://g20.bimmerpost.com/forums/sh....php?t=1662914
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
