04-27-2020, 05:32 PM | #1 |
196
Rep 210
Dimpled Slotted Brake Rotor Noises
I purchased zimmermann dimple slotted rotors and akebono eur pads for my 340i, when i put them on they were grinding and making all types of noises especially when driving next to curbs or walls. I also read on this forum several other members who had this issue and I heard someone changed their brake pads to OEM pads and that solved the issue......and it has for me. My reasoning on why OEM pads dont make the fluttering noise is because they do not have a slot in the middle that create a air channel that pushes air into the slots and dimples. See photos for comparison:
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
04-27-2020, 07:54 PM | #2 |
212
Rep 231
I’m on OEM pads and still get that noise you’re talking about. Maybe it’s a YMMV thing?
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
04-27-2020, 09:14 PM | #3 |
88
Rep 279
its the dimples, i drilled through the dimples and the noise is significantly less, i get no noise on my driver side but a lil on the passenger, but a lot less that ppl can't here it.
I won't be going dimpled rotors next time around Last edited by pongkin; 06-03-2020 at 09:02 PM.. |
04-27-2020, 09:38 PM | #4 |
196
Rep 210
mine definitely have no noise. I greased the backsides of the pads too, maybe that is what makes a difference? Maybe the materials also?
34116878882 is the part number I use they are the genuine mperformance brake pads.
04-27-2020, 09:55 PM | #6 |
196
Rep 210
Ebc red pads have a slot if I remember correctly
04-27-2020, 11:23 PM | #7 | |
4528
Rep 5,394
Drives: 2015 BMW 335i x-Drive Auto
I've seen dimpled rotors where the dimples appear rusty. Someone told me that the dimples aren't rusted but that they pickup material that rusts. All I know is they looked like rotors full of rusty dots. |
exE36M3487.50 |
04-28-2020, 12:26 AM | #8 | ||
242
Rep 765
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-28-2020, 12:49 AM | #9 |
479
Rep 797
I have EBC redstuff pads and the dimpled/slotted rotors. I do have the noise when next to a wall. It's the same on both sides and it doesn't change at all. It's definitely just the air noise from the rotors. Next time I'll probably go with blank rotors.
05-01-2020, 12:43 PM | #10 |
1307
Rep 1,827
I can also confirm that dimpled & slotted rotors paired with Hawk HPS 5.0 pads make noise. I've mostly gotten used to it, and I'm personally ok with the trade off.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
05-01-2020, 08:45 PM | #11 |
196
Rep 210
Do those pads have slots?
05-02-2020, 09:19 PM | #12 |
1307
Rep 1,827
From my recollection, yes, they do have the groove in the center.
05-02-2020, 09:50 PM | #13 | |
196
Rep 210
jh_f301307.00 |
05-02-2020, 09:58 PM | #14 |
88
Rep 279
05-02-2020, 09:59 PM | #15 |
196
Rep 210
That's what this thread was about
05-02-2020, 11:18 PM | #16 | ||
1307
Rep 1,827
05-03-2020, 08:33 AM | #18 |
1307
Rep 1,827
Really? I had no idea. I'm open to doing some testing. Feel free to shoot me a DM to work out details.
05-11-2020, 05:56 PM | #19 | |
309
Rep 272
I’m kind of ocd with noise I probably would replace the square cut seals in the pistons if mine were grinding. My first instinct would be that the piston isn’t retracting enough to pull the pad off the rotor. |
06-16-2020, 12:28 PM | #22 |
Rep 7
can someone give a good description or take a video of this noise and how bad it is?
for those who have had it for a long period of time, does it still bother you? |
