Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Code speedometer limit from 260 to 330?
      04-25-2020, 11:21 PM   #1
sddz6269
China
32
Drives: BMW G20 325i
Hi, I wonder how I can change my speedometer range from 0-260 to 0-330. I know it's possible in esys but don't know how to do this using Bimmercode. Thanks!
      04-25-2020, 11:54 PM   #2
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
Search for ag_mpa_msp_view
Appreciate 3
      04-26-2020, 01:00 AM   #3
sddz6269
China
32
jaimeen77 Thx man. I'll try later. And do you know how to change the Fuel consumption display maximum value? On the official website it says this could be coded in “Instrument Cluster” KOMBI_CT_RD1 control unit. However, I could not find it.
      04-26-2020, 01:10 AM   #4
sddz6269
China
32
      04-29-2020, 08:00 PM   #5
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
Can you explain more about it???
Or do you have a screen shot?
I dont actually get what do you want to change.
      04-30-2020, 09:24 AM   #6
bumbumquietsch
Drives: BMW G20 330i
The max value for fuel consumption.
Can be found under Kombiinstrument. No need for expert mode.
In german the parameter is called "Verbrauchsanzeige Maximalwert" and can be changed from 20 l / 100km to 30 l / 100km
      05-01-2020, 11:36 AM   #7
Rednose_M340i
Rednose_M340i's Avatar
Belgium
67
Drives: BMW M340i
Thanks! I was looking for this and it works like a charm
      05-02-2020, 06:49 AM   #8
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
One of the selectable dashboard widgets displays: Odometer, miles on current tank of gas & average speed. I want to change average speed to average fuel consumption.
Anyone know how to code this KOMBI?
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      05-02-2020, 08:24 AM   #9
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
Originally Posted by RSnic View Post
Hi,
Thanks
Isnt it default??
      05-02-2020, 08:25 PM   #10
RSnic
RSnic's Avatar
Hi,
Thanks
Isnt it default??
@jaimeen77 ,
What I described is one of several selectable items on the right of the instrument panel by using the upper button on left stalk. I would like to change an item in one of these
Thanks
Al
Retired: 2014 328i
BMW CCA
      05-29-2020, 09:35 AM   #11
A6bullet
Germany
337
Drives: 2020 330i Msport
Under what module was it?
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      05-29-2020, 10:23 AM   #12
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
DKOMBI it is.
A6bullet337.00
      07-23-2020, 04:12 AM   #13
Exbenzbimmerlover
Drives: X3 m40i
Does anybody know if this works on idrive 6??
      09-16-2020, 02:24 PM   #14
rockblock
rockblock's Avatar
57
Drives: 2023 M240 xDrive
Why doesn't the RPM show 8 (x1000)?...the US version shows 200 mph & 8 RPMs
      09-16-2020, 05:45 PM   #15
Rednose_M340i
Belgium
67
Drives: BMW M340i
Because i use the original display and not the "M" one. I only changed the 260km/h to 330km/h.
      09-16-2020, 10:58 PM   #16
rockblock
rockblock's Avatar
57
I see... Good to know you can do both. Cheers
      09-17-2020, 09:17 AM   #17
Brendan D
Drives: G20 3 Series BMW
Still looking for away to go to 260 rather than 330 on the Alpina display.....
      11-01-2020, 03:56 PM   #18
thelmers
Netherlands
Drives: BMW M340i xDrive Touring
I own a M340i and I want also want to modify the speedo. I want to keep the original design, but I do not need 330.
Is there a possibility to put it on 300 kmh? Or is it only possible to choose between 260 or 330 kmh.
      11-06-2020, 05:17 AM   #19
PunkSinatra
78
Drives: Alpina D5S
You can only choose between 260 and 330 on the original cluster.
      05-18-2021, 04:22 PM   #20
rico25
rico25's Avatar
37
Drives: #G20
hey man! how do you find how to change from 0-260 to 0-330 in Bimmercode? I wonder if it would work on the alpina display as well. Thanks
      05-23-2021, 01:51 PM   #21
Rednose_M340i
Belgium
67
Drives: BMW M340i
Go to "Instrument Cluster" DKOMBI4 control unit
Then choose "Expert mode"
and search for: ag_mpa_msp_view and set 330
      07-26-2023, 11:22 AM   #22
crashtwo
crashtwo's Avatar
Belgium
Drives: BMW X4 M40i
Hi mate!
I don’t have the choice.
As you can see on this picture, I only have the one non-marked by a red X
Can someone help me?
g20
