04-22-2020, 09:28 PM | #1 |
Rep 10
USB Resume Problem
Hi,
We recently took delivery of a 2020 M40i, love it but having one issue, if I play music from USB, when I start the car it does not resume at the point I left off, it goes back and plays the first alphabetical song on the drive. Anyone else experienced this issue? My M240 works flawlessly from the USB. Last edited by AwesomeIcey; 04-23-2020 at 09:05 AM.. |
04-23-2020, 12:26 PM | #2 |
541
Rep 2,073
I’ve not checked one suggested fix yet. USB 3 sticks seem to be the issue. It’s said that USB 2 work ok as does music on the HDD. I have too much music for the HDD so use 2x 256gb sticks...both are 3s.
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D Last edited by clivem2; 04-23-2020 at 12:45 PM.. |
04-23-2020, 12:38 PM | #3 |
795
Rep 1,959
https://www.civicx.com/forum/threads...ar-start.6716/
Seems like a reasonable assumption. Curious why partition format would matter. Maybe their sub-code for that particular function is sourced from a major publisher that has a similar bug. https://www.makeuseof.com/tag/format...ive-fat-fat32/ ^In any case, try a reformat. Not sure what the max supported partition size for FAT32 on iDrive 6/7 is, though... |
04-24-2020, 07:11 AM | #4 |
783
Rep 911
Drives: 2020 X3 M40i
Have you tried to copy you music from the USB stick to the built in hard drive? I am aware that doesn’t actually answer you question, but it may provide a solution.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
04-24-2020, 08:23 AM | #5 | |
541
Rep 2,073
It was fine on my F25....it's even same USB3 stick too.
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D |
04-26-2020, 03:11 PM | #6 |
17
Rep 57
Similar problem with Ipod
I've noticed similar behavior with my older Ipod. Sometimes I have to disconnect the USB Ipod cable from the car and reconnect. Also, for some strange reason, it sometimes won't play some songs on the Ipod at all.
I've copied those songs (and others) to the Music bank and everything works fine. I may just moved most songs to the car, but I'd rather not. Thoughts? '20 X4 with latest IDrive 7 update applied |
05-04-2020, 09:37 PM | #7 |
Rep 10
I've been doing some messing around... not driving much so taking a lot of time to test...
Both keys are USB3, in fact both are SanDisk UltraFit keys, one is the latest model (256GB) though and the other is a year older (128GB) The new usb-key was formatted as Fat32, the old one as exfat, formatted them both the same to exfat but had same problems in the X3. Swapped the usb-keys, the one that is in the 2 resumes like normal in the X3. Put the new key into the 2, it's only been 2 trips but it seems to resume fine. Really no idea why it would make a difference unless the iDrive 7 in the X3 does something different at startup and the bigger key somehow confuses it... Likely have a working solution but frustrating problem.. |
