Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions SLI working with Navi Data
      04-22-2020, 05:08 PM   #1
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
I still have to document the changes I made in ESYS but was able to get SLI to work without FSC.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      04-22-2020, 08:22 PM   #2
Crazy Penguin
117
Drives: Jet Black
Is this backwards compatible you think to F series? 🧐
      04-23-2020, 09:54 PM   #3
Bmw340JP
Drives: bmw 340
Good coding
Attachment 2291927
HOW TO CODE IT without FSC ??
      04-24-2020, 11:56 AM   #4
greekcs
greekcs's Avatar
Kombi
kafas
      04-25-2020, 03:27 PM   #5
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
How can I find the 'kafas' menu via BimmerCode?
      04-25-2020, 05:17 PM   #6
greekcs
greekcs's Avatar
I don't think its available in Bimmercode. E-sys is the only way for now.
MY8615.00
      04-26-2020, 04:38 AM   #7
MY86
MY86's Avatar
Turkey
15
I did the things under the 'Kombi' section via BimmerCode and it worked. But I could not find the 'Kafas' section. 'SLITSM_ACTIVATION - Navigation only' Can't find this.
      04-26-2020, 10:44 PM   #8
Bmw340JP
Drives: bmw 340
Good coding
thank u for ur share
It's WORKING now !!!
greekcs773.00
      04-27-2020, 04:10 AM   #9
MY86
MY86's Avatar
Turkey
15
How did you find the Kafas section?
      04-27-2020, 04:32 AM   #10
Bmw340JP
Drives: bmw 340
Good coding
I use E-SYS
      04-27-2020, 01:50 PM   #11
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
KAFAS is different ecu. This ecu is a camera in front middle mirror.
MY8615.00
      04-29-2020, 03:17 AM   #12
MY86
MY86's Avatar
Turkey
15
So, I can’t find ‘Kafas’ in BimmerCode even in the expert mode?
      04-29-2020, 04:16 AM   #13
MY86
MY86's Avatar
Turkey
15
I did the first part with 'Kombi'. It appeared on the cluster but only says LIMIT.
How can I do the second part with 'Kafas'? The only way is to do it is E-sys?
      04-30-2020, 03:47 PM   #14
igorbutarev
Russia
26
Kafas (front camera) is a different ecu. It's like Bdc, kombi, mgu, not a section. Some cars has kafas, some don't. It depends of vehicle order (FA).
MY8615.00
      05-02-2020, 03:20 PM   #15
greekcs
greekcs's Avatar
I tried to take it a step further and order the FSC code for SLI. Unfortunately its not available.
AppID 331 (14B) -> MID SLI
US vehicles come standard with Active Guard (5AV). European cars have Active Guard plus (5AQ) which also includes SLI. I wonder what would happen if I replaced 5AV with 5AQ.
Update: 5AQ didnt work
      05-03-2020, 02:37 PM   #16
Marcelo_BSB
Drives: 328
what is navi data?
I saw the 3 changes via e-sys but limit appears in the circle.
What is missing?
      06-01-2020, 08:39 AM   #17
biglesias31
biglesias31's Avatar
Drives: BMW X3
Bump
      06-03-2020, 06:46 AM   #18
A6bullet
Germany
337
Drives: 2020 330i Msport
Is KAFAS in reference to the new triple camera system or does that term apply to the single camera system.
Reason I ask is becasue I have the single camere "KAFAS" but the SLI works fine. I havent gone into the ECUs to see if theres a difference.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      06-03-2020, 03:55 PM   #19
biglesias31
Drives: BMW X3
I have the single Kafas camera also but I don't know why my vehicle didn't come with Speed Limit Info
      11-27-2021, 07:05 PM   #20
fkyang
Taiwan
20
Drives: BMW G20 320i M sport
Hi
May I know which parts you changed in Kombi via Bimmercode?
      11-28-2021, 09:42 AM   #21
Ahmaddoski
17
Drives: 2020 bmw 330i Us spec
My car (US imported) came with sli from factory but as it seems it doesn't work here because it doesn't have my countries navigation maps in it or it's not supported here, is there a way to make it only rely on kafas camera and be separate from navigation data ?
      11-30-2021, 01:18 AM   #22
maximking
108
Drives: F10
some cars have the FSC for speed limit info already inside . it's a matter of coding only to enable it for display.
g20
