Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions RDC widget on 6U3 live cockpit professional
      04-22-2020, 07:59 AM   #1
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
Hi. Has someone knows the parameter in DKOMBI4 to code this ?
      04-22-2020, 01:13 PM   #2
Alex2020g20
Alex2020g20's Avatar
Drives: 2020 BMW 330i M-Sport
I would love to find out too, that looks awesome!
      04-23-2020, 06:32 AM   #3
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
Is this widget displaying tire pressure & temperature of all tires -- sorry, I can't read Cyrillic?
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      04-23-2020, 06:33 AM   #4
phillyd2
216
Drives: 2020 M340i XDrive
Nyet
      04-23-2020, 10:45 AM   #5
igorbutarev
Russia
26
Originally Posted by RSnic View Post
Hi,
Thanks
Yes
      04-23-2020, 10:47 AM   #6
tommytexter
tommytexter's Avatar
182
Drives: 2020 M340ix
What to know too!! Possible to code M8 track mode gauge too?
      04-24-2020, 05:29 AM   #7
sddz6269
China
32
Drives: BMW G20 325i
I checked his instagram and asked him if this could be coded on G20 330i and he said yes. But still dunno how to do that.
Appreciate 2
      05-04-2020, 09:59 AM   #8
Rastlein
Drives: BMW 320i
Has anyone been able to encode this with Bimmercode? I've also seen a widget with turbo pressure, oil temperature, etc. I would be interested to know how to code it too.
Andy3661121.50
      05-04-2020, 03:33 PM   #9
victordura
330i M
victordura's Avatar
Spain
8
Drives: 330i M
Hi! I have coded it but only partially. Display only shows temp and pressure but not the car with green tires.
I can’t remember which parameter is in bimmercode but I will try to remember or search for it on weekend.
VD
      05-04-2020, 10:29 PM   #10
sddz6269
China
32
VD
That would be great. But how did you find how to code that then?
      05-05-2020, 01:23 AM   #11
victordura
330i M
victordura's Avatar
Spain
8
Drives: 330i M
I modified some parameters of the Instrument Cluster module that seemed interesting because the name. I think the RDC widget involves two lines of coding because the car image is missing in mine.
If O find some time I will try to find out the other line and remember the one I modified.
I will write it here.
VD
Appreciate 2
VipinLJ1936.50
RSnic657.50
      05-07-2020, 10:22 AM   #12
RSnic
RSnic's Avatar
VD
@victordura ,
Using E-Sys, I just scoured DKOMBI4 CAFD (Instrument Panel) for anything with RDC, Reifen (tire) Druck, Safefy & RDC_Safety and unfortunately came up dry
Do you recall what function you changed?
Thanks
Al
Retired: 2014 328i
BMW CCA
      05-07-2020, 05:37 PM   #13
victordura
330i M
victordura's Avatar
Spain
8
Drives: 330i M
@victordura ,
Thanks
Not yet! I haven’t got any time this week. I hope to be able to check it again on weekend.
I will find it again for sure. I hope, because I need to remove 2 widgets that appeared after coding another to lines but don’t work properly.
One is turbo pressure and water temp.
The second widget I have to get rid of is M widget for steering, brakes and engine configuration.
VD
      05-08-2020, 03:26 AM   #14
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
137
Drives: BMW 316d, BMW F40 116d
If you can, can you send me the ncd file of the dkomb so I can search for it to?
Haven’t had a G20 yet to code. So it will help allot to search actively to!
      05-08-2020, 06:05 AM   #15
Rastlein
Drives: BMW 320i
VD
Haven't you seen any widget to show the oil temperature? It would be great.
Thank you!
      05-08-2020, 07:02 AM   #16
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Unhappy
VD
Hi,
Do you also have any idea about how to enable the G- Meter widget on the live cockpit and the ID 7 ?
Could you also take a look on that?
My car did not come with this widget enabled from the factory
      05-09-2020, 01:53 PM   #17
RSnic
RSnic's Avatar
Hi,
Went exploring through DKOMBI4 with Bimmercode in Expert mode and ran across CB_WIDGET_GWSZ_TWSZ, under Configuration function & it was not active
Anyone have any idea what this is? Is this the tire pressure & temperature widget?
Thanks
Al
Retired: 2014 328i
BMW CCA
      05-09-2020, 09:30 PM   #18
g20beam
g20beam's Avatar
468
Drives: G20 330i M Sport
2019 BMW  [0.00]
Hi,
Thanks
I'll test later but that might be it, thanks for that, I will confirm if it works
      05-10-2020, 02:27 AM   #19
igorbutarev
Russia
26
Hi,
Thanks
Now checked it. Don't work(( I will continue finding solution
      05-10-2020, 07:03 AM   #20
sddz6269
China
32
Hi,
Thanks
I coded every item that contains "WIDGET" into "aktiv" but nothing seemed to change
VipinLJ1936.50
      05-10-2020, 03:07 PM   #21
RSnic
RSnic's Avatar
Hi,
Thanks
Well, thanks to Stephan from Bimmercode for the following: GWSZ is “Gesamtwegstreckenzähler” and this is “total distance counter” in english.
Therefore, what I thought was a good lead is a not
Sorry!
Al
Retired: 2014 328i
BMW CCA
      05-12-2020, 05:00 AM   #22
sddz6269
China
32
VD
victordura Hi, do you remember if these parameters contain similar elements, like, do they all start with "CB" or something like that. Muchas gracias!
Search this Thread:
Advanced Search
g20
