04-22-2020, 02:17 AM | #1 |
101
Rep 280
How can I make this look better?
Long story short, I had my rear bumper repainted after just 2 months of ownership due to someone scuffing it and not leaving a note and while the paint and finish is in general pretty good, I’m really not happy about the finish around the parking sensor at the driver’s side rear. It wasn’t a BMW body shop that painted it, by the way.
I showed it to the paint shop and they said it’d never be perfect unless they removed the bumper and sensor holder and painted it again from scratch (they painted the bumper with it still on the car and I’m really not keen on going down this route for such a small area) I’ve tried brushing in some touch up paint and am thinking I can flat it back with wet and dry to make it less noticeable or I have a rattle can so might attempt to mask and spray just this area. Any suggestions on how to get it better? Before and after shots attached. Last edited by ClaretFozzy; 04-22-2020 at 03:15 AM.. |
04-22-2020, 02:39 AM | #2 |
39
Rep 219
How much cut and polish have you given it? with it having "terrrain" you have have to be a little bit difficult - but i would have though you can get it a little more even. You may take all the paint off - but frankly if you do you have lost nothing as from where you stand it would need paint anyway....
I've made worse look better.... with a bit of work. I have also had it go wrong and stumped up for paint... (For the record - im not a detailer )
Cheers, Paul
__________________________________________________ ________________ G02 X4 MSport X - Carbon Black w Black / Comfort Pack / Tech Pack / Privacy |
04-22-2020, 02:48 AM | #3 |
101
Rep 280
Hi, thanks for the reply.
I’ve not polished it at all yet. I’ve simply brushed/dabbed paint on and removed any excess with paint thinners. Last edited by ClaretFozzy; 04-22-2020 at 03:16 AM.. |
04-22-2020, 03:50 PM | #5 |
323
Rep 429
Hard to tell from the pic just how noticeable it is. A rattle can would only work if you could effectively mask off an area and not have a seam there when you remove the tape. If you can't do that you'll have a large area to feather and blend by wet sanding and then applying clearcoat and doing the same, followed by polishing compound. A small repair would be a lot of work and you could easily make it worse.
04-22-2020, 03:55 PM | #6 | |
101
Rep 280
04-23-2020, 07:43 AM | #7 |
39
Rep 219
i think that would be a disaster - can you not remove it from the bumper?
Cheers, Paul
04-23-2020, 03:20 PM | #8 |
101
Rep 280
04-23-2020, 04:18 PM | #11 |
541
Rep 2,073
I agree with Teaston really. Leave it alone. You’ll only make it much worse.
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D |
04-24-2020, 03:43 AM | #13 |
101
Rep 280
My wife keeps saying the exact thing, as I spend ‘just another’ hour trying to make it look 5% better.
And yes, I do have OCD Last edited by ClaretFozzy; 04-24-2020 at 04:06 AM.. |
