BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
BPM
      09-15-2008, 08:59 PM   #1
man02195
man02195's Avatar
19
Drives: e90 M3 M-DCT, SG-status 111
VIR Track Report, 3 M-DCT cars at HPDE
There were 3 M-DCT cars at VIR this past weekend. One in the instructor group, one in A group, and one in D group.
The car is really strong, really easy to drive fast, and everything held up great for the weekend.
The car just keeps going and going, there was a vette and a couple of gt2/3s in our group that would slowly pull away from me, but not much else. The speedo showed 145-150, but my performance box only registered 140 or so on the front and back straights.
Tires: I brought TRMotorsports 18x9 with 265-35-18 BFGoodrich gForce R1s on all 4 corners. The wore well, handled great, and I'd definitely recommend them. I ran w/o spacers all around, and also kept them around 42 psi hot. Front left had more wear on the shoulder, so I let it run a few psi higher and rotated them on Sunday morning.
Brakes: Stock and Brake Fluid: Stock, There was some fade compared to my 330i with hawk ht-10 brake pads, so I'm waiting for the new PF-06's to be out in 2 months or so.
The oil temp rose to about 250 or so during the 20 minute run sessions, with 93 to 96 degree ambient. It would cool down to 210 after a leisure trip around the paddock.
Oil consumption: didn't move the electronic dipstick during the weekend
Fuel consumption: not that good, but at least the track had plenty of premium gas at $4.55, hurricane Ike caused shortages at gas stations across north carolina and virginia over the weekend.
I ran in M-Dynamic mode, didn't want to go DSC off for my first time with the car. It intevenes about 3 times each lap, but not enough to stop the fun.
M-DCT downshift issue: Yes
All 3 of us experienced the "I just don't want to shift" issue. So I'd finish braking, and as soon as I started my turn-in, I'd click click click from 6th to 3rd and start to roll into the throttle before the apex. Hope they can fix that via software.
Added a couple of pictures
E90 M3 Sedan
      09-15-2008, 10:06 PM   #2
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Stock pads are definitely not up to the task when you really get on them. I'm stopping by Turner soon to get a set of Pagid RS-19s. I've already replaced the stock fluid, and it didn't boil.
My experience with oil temps has been similar.
      09-15-2008, 11:04 PM   #3
swamp2
swamp2's Avatar
Drives: E92 M3
What is the story with the these Pagids? Streetable or no? Loud and squeeky when cold? Any idea on how bad they dust? I.e. just a track only pad? Going for fronts and rears? Cost? Still considering OEM BMW track pads?
      09-15-2008, 11:27 PM   #4
lucid
lucid's Avatar
They're about $750 for the entire set. I believe that is considerably cheaper than BMW track pads; folks have posted on the forum their dealers want $1400 for the BMW pads. I understand Pagid RS19s when excellent bite when hot, and do OK when cold, but are very noisy. I've got 4 track days in mind for October, and then will swap them out for the winter.
Here is the "friction vs temp" graphs for the different Pagid compounds although I don't really understand what has been plotted exactly:
http://www.livermoreperformance.com/pagid.html#graph
It looks like coefficient of friction, but against what type of disc surface exactly? The disclaimer acknowledges that the coefficient of friction is related to disc material, and the chart does not include any values for the y-axis. I must assume they tested the coefficient of friction on the same disc for the different compounds listed, but do not want to publish any values since they will vary depending on disc material.
Don't know anything about how dusty the RS-19s are.
Scroll to the top of that page for the official description of the compounds.
      09-15-2008, 11:28 PM   #5
JAJ
80
Drives: 2014 Shelby GT500
Pagid RS19's on the street:
Noise: Think school bus on steroids. Really noisy once they're bedded in and well used.
Dust: not bad, really.
Modulation: My wife refuses to drive the car with them on. Nose-bleed inducing if someone cuts you off and you tag the pedal in a hurry. Phenomenal at speed when hot.
Cost: $800 for both axles. I would NOT mix them with anything else.
Rotors: you need factory rotors with part numbers ending with "38x" where "x" is 5, 6, 7 or 8 depending on which corner you look at. You can see the numbers stamped into the rotor centers by looking through the wheels.
Other notes: the rears work really hard on the track if you don't turn DSC to M-dynamic mode.
OEM sport pads are hard to get and expensive. I priced them at $1500 in Canada, "not available" in the USA.
      09-15-2008, 11:30 PM   #6
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Do you know what the offset of the TR Motorsport wheels are? What about the weight of the wheels?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      09-15-2008, 11:35 PM   #7
skierman64
skierman64's Avatar
2011 BMW Z4  [0.00]
Oh, one other question, what did the other MDCT owners have to say about driving it on the track? Obviously, we all know about the downshifting issue, no need to repeat those comments.
Did you get any pad transfer and thus vibration from the front rotors?
I used the same technique for downshifting...after turn in and before the apex. It worked ok, but it certainly is a compromise.
      09-16-2008, 11:33 AM   #8
man02195
man02195's Avatar
19
skierman,
Here's sayemthree's thread on the wheels/tires
http://www.m3post.com/forums/showthr...87#post2935787
E90 M3 Sedan
      09-16-2008, 11:56 AM   #9
man02195
man02195's Avatar
19
We all thought M-DCT was amazing, shifts were seamless, and you could just nail it every time at 8,000 rpm or whatever point you picked. Instead of hanging out in a gear that could be too high or too low for what comes next, you can instantly change the gear.
I did not have any vibration from the rotors, one of the other guys had one front rotor that had some vibration (we swapped the front tires and spun the rotors to see if it was warpage or deposits, he's taking it to dealer to check it out).
E90 M3 Sedan
      09-16-2008, 12:36 PM   #10
consolidated
consolidated's Avatar
205
Drives: F80 M3
Pagid yellows (19) are an endurance racing pad. I've got over 12 days on a set and they're about 50% used up. Pagid representatives have told me some team will run an entire 24 hour event with one set, yikes.
Very very noisy on the street. Tried non-squeal sprays and backer plates to no use.
      09-16-2008, 01:02 PM   #11
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
If they worked on the street, probably be too perfect.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      09-16-2008, 01:08 PM   #12
GT3 Tim
Moderator
GT3 Tim's Avatar
Drives: 2014 MB E63S
Spot on with the RS19 review.
I had them on my GT3 and loved them, asside from the sqeal-like-a-bus noise when they are cold....although I didn't care that much....but you WILL get looks from other peeps like "WTF is wrong with your car? Can't you hear that??" LOL
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket
2014 F30 328i -- Kids car
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      09-16-2008, 01:09 PM   #13
GT3 Tim
Moderator
GT3 Tim's Avatar
They work fine when cold, just a bit noisy!
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      09-16-2008, 03:25 PM   #14
man02195
man02195's Avatar
19
Stock pads are definitely not up to the task when you really get on them. I'm stopping by Turner soon to get a set of Pagid RS-19s. I've already replaced the stock fluid, and it didn't boil. My experience with oil temps has been similar.
Here's a communication from bimmerworld on the PF-06 coming out soon:
We do not have one yet. Our M3 is currently down at PFC so that they can get a pad shape for the pads and also design a big brake kit. Assuming all goes well it will take a couple of months to get pads made for the car. I also spoke with Hawk and they are still a couple of months out on pads for that car.
E90 M3 Sedan
      09-16-2008, 08:20 PM   #15
man02195
man02195's Avatar
19
Here's some feedback from a guy I know at BMW:
"It's a software issue that has been resolved. It should be available around the first of October."
E90 M3 Sedan
      09-16-2008, 11:47 PM   #16
JAJ
80
Yeah, pretty much dead accurate. I just smile at the folks wondering what's wrong.
I installed Stoptech stainless flex lines and Castrol SRF fluid in my system - the combination has really firmed up the pedal - it's like driving with a BBK and the pedal doesn't sink when the brakes heat up - heel and toe is much more consistent.
      09-18-2008, 10:35 AM   #17
sfbimmer13
Original Bavarian Heritage
sfbimmer13's Avatar
Drives: 2008 E92 M3 DCT
matches my experience with them 100% - I would also highly recommend against using them only in the front, your brake bias will shift too much...
2008 E92 M3 M-DCT - Sparkling Graphite - Fox Red - Tech Package - Premium Package - Moonroof - Enhanced Premium Sound - HD Radio - iPod USB interface - PDC - Remus Race Exhaust
Search this Thread:
Advanced Search
m3post
