04-18-2020, 11:20 AM | #1 |
Rep 10
F31 with 18 x 8.5 square?
I picked up a 2015 F31 yesterday. Original owner must have had issues parking as the 397s are beat to hell.
The Wagon is kind of an oddball as it has: Sportline DHP M Suspension M Brakes Looking for a new set of wheels for it and was wondering if I can run 18x8.5 square on it? What ET should an 8.5 be? |
04-18-2020, 11:30 AM | #2 | |
1599
Rep 3,748
Someone might have there own suggestions... they will just have to speak up. |
alohasurftoad3113.50 |
04-18-2020, 11:57 AM | #3 | |
3114
Rep 4,361
for tire sizes 255/40/18, most grip, fills some wheel gap with flushness, i'd do ET35 if 255 due to width. 235/45/18, better ride and impact, fills profile wheel gap some 245/40/18, increases wheel gap, so better if lowered for a 4cyl with x-drive at stock height i'd use 235/45/18 but other choices are fine also. |
04-18-2020, 11:02 PM | #5 |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
I run a square set of Apex SM-10 18x8.5 ET35 with 245/40r18 tires no problem on my F31.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-20-2020, 03:19 AM | #6 |
569
Rep 611
Based on my recent experience, I can only recommend going wider at the front. With significantly more grip, less understeer and improved steering feel, changing the stock 225's for 245's made even bigger difference than I hoped for.
04-26-2020, 04:12 AM | #7 |
Rep 32
Drives: 2015 YMB F82 & 2015 AW F31
Has anyone run a set of BMW's 437M wheels off an M3/M4?! Or a similar setup? Wheels are 19"x10" and current tires measure 275x35x19 rears and 255x35x19 fronts.
Anyone have any idea if I could run these on my 2015 F31?! Thanks! |
04-26-2020, 06:35 AM | #8 | |
54
Rep 286
17' 340ix|Track Handling Package|MPPSK|MP Stage 2.5 ECU Tune|MP Stage 2 Trans Tune|AP Intake|763M Wheels
04-26-2020, 12:51 PM | #9 |
480
Rep 681
I run those on my f31. You can't run that exact tire combo with xdrive. You could run 235/40/19 and 265/35/19 or 245/35 and 285/30 (although you might have rubbing with 285 in the rear without some added camber/lowering)
2016 328ix F31 - SOLD!
2006 997.1 C4S |
04-28-2020, 03:13 AM | #10 |
Rep 32
Thanks Andino- apologies for my ignorance but why does the sidewall height need to be higher in the front than rear? I am fairly certain my existing tires are 225/45/18 all around but I will have to check tomorrow to be sure. I'd be psyched to run the 437s with the tires that are already on them but they are 255/35/19 and 275/35/19 so I might have to pick up a different size..?!
04-28-2020, 09:07 AM | #11 |
3114
Rep 4,361
Codestar is running 255-275(2.3%) on his xdrive without issues...https://f30.bimmerpost.com/forums/sh...5&postcount=61. General consensus is having front and rear diameters equal or close as possible is better for the x-drive transfer case, though. So proceed at your own risk!
Another size combo is 255/35/19-265/35/19(1.2%). https://f30.bimmerpost.com/forums/sh...&postcount=265. I think he's selling these wheels with 245/35-285/30 in the classifieds. Last edited by alohasurftoad; 04-28-2020 at 11:22 AM.. |
04-28-2020, 11:55 AM | #12 | |
480
Rep 681
I would really recommend keeping the difference between front and rear tires as close to 0% as possible. I noticed some hesitation when running 513ms with a staggered tire fitment of 0.4% difference. YMMV but that's why I try to minimal the difference if I can.
2006 997.1 C4S |
05-06-2020, 07:33 PM | #13 |
Rep 2
What about 18x8 square?
Not to hijack the thread, but I have an F31 M Sport with 18x8 square. Any recommendations on doing something wider than the stock 225 tires? I've seen 245/40/18 suggested.
Thanks. |
05-06-2020, 09:08 PM | #14 | |
3114
Rep 4,361
235/45/18 will reduce some wheel gap and is the size i'd recommend on unlowered xdrives. the larger sidewall will provide a better ride and impact protection, trading off just 10mm width compared to a 245/40/18. https://f30.bimmerpost.com/forums/sh...F45%2F18+dummy i do not recommend 245/45/18 because wider, heavier and taller(geared) will decrease acceleration, braking, turn-in. large sidewalls makes the wheel look smaller in diameter and look too rally cross'ish |
J555568.50 |
Tags |
f31 |
