BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 275 rear 245 front on XI
      04-17-2020, 11:41 AM   #1
cortez08
60
Drives: 2008 335xi
Is anyone running 275 rear and 245 front on XI? If yes rim specs? What coilovers are you running? Spacers? Fender roll? Any other clearance issues?
      04-17-2020, 12:32 PM   #2
Impreza98
12
Drives: e90 335i and 05 STI
I am running those sized tires on an LCI XI. Wheels are bmw style 513m with koni special active struts and dinan springs. No spacers or fender roll.
      04-18-2020, 05:32 PM   #3
Bimmer_Bro
Bimmer_Bro's Avatar
393
Drives: 2010 BMW 335xi LCI
I am running 275/30/19 on the rear with 235/35/19 on the front. Avant Garde 19’’ rims. My car is slammed on st coil overs. No rubbing, no spacers . Figment is perfect. Was told by my tuner that this set up circumference is within 1% of each other so it is suitable for the xdrive system.
I could try and dig up my rim specks if needed.. Offset is different on the rear vs front.
Instagram : @Bimmer_bro
      04-22-2020, 11:13 AM   #4
csteege
Drives: 335xi
275/30 19 and 235/35 19 zero issues with 225,000 miles. Oh and 437M wheels
      04-22-2020, 12:34 PM   #5
matteblue3er
238
Drives: Racecar
I run 255/40/17 in front with et30. 10mm spacers I believe on H&R coilovers
I'm running a square setup so it's the same in the back but with 15mm spacers
      04-24-2020, 03:44 PM   #6
Boosted12a
68
Drives: BMW 335i x
This is great! But lci/ pre lci have different track in the rear. Rim width/ offset would be nice info too.
      06-23-2020, 01:21 PM   #7
RB
Been around for a while
8
Drives: E90 335i; xDrive SE; Jerez
2011 BMW 335i  [0.00]
I'm running 245/40/18 on the front and 275/35/18 on the rear of my 2011 335i xDrive.
Wheels are matte black VMR VB3 18x8.5 ET 40 on the front and 18x9.5 ET 33 on the rear.
I've used this setup for track with Hankook Ventus R-S3 and Dunlop Direzza ZII and street with Hankook Ventus V12 evo K110.
Stock suspension and alignment, no spacers and no mods.
No clearance issues.
Appreciate 2
      06-26-2020, 09:54 PM   #8
335xs2dinan
335xs2dinan's Avatar
141
Drives: 08 E92 335xi, 22 G80 M3
can you post a picture? also is your car lowered, im interested in fitment with same wheels and tire sizes on lowered x-drive. thank you
Dinan Stage 3/Cobb FMIC/ER Sport Oil Cooler/CPE Catted DP/BMS DCI/Eisenman Race/Koni Yellow F + Dinan R/Dinan Springs/UUC F + R Sways/M3 subframe bushings/OEM 313 Wheels/M3 steering wheel
