Nothing above 87 octane gas available
09-15-2008, 09:34 AM | #1 |
65
Rep 222
First off, I am sorry to whoever has sustained any sort of damage to their homes or who has had to evacuate because of Ike. I know my issues miniscule to yours.
Anyway, because of the refineries that were shut down, there's no gas available other than 87-octane. How much of a problem will it be if I use 87 octane and what can I do to make it less of a problem? |
09-15-2008, 09:54 AM | #2 |
424
Rep 4,709
Wow, seriously? I never thought that would happen. A LOT of cars in your area must be SoL then...
Well, off the top of my head, you could look into using octane booster, which is available at local auto part stores. Be cautious in using it though. |
09-15-2008, 09:57 AM | #3 |
131
Rep 2,086
putting 87 in a car shouldbe the least of your problems, considering the devistation from Ike.
your car will be 100% fine if you put half a tank in, and then out in 91 or 93 on the next fill up
2013 MB C300 4matic
2014 Ford Explorer Ltd 1973 Jeep Commando |
09-15-2008, 10:04 AM | #4 |
this is the way
18149
Rep 8,527
This is from the manual. If you have a 335 your SOL; it requires 89 minimum. Lucky your car is a 328
Required fuel Super Premium Gasoline/AKI 91 This gasoline is highly recommended. However, you may also use gasoline with less AKI. The minimum AKI Rating is:
the engine may produce knocking sounds when starting at high outside temperatures. This has no effect on the engine life. Do not use any gasoline below the specified minimum fuel grade. Otherwise the engine could be damaged. |
09-15-2008, 10:49 AM | #6 |
374
Rep 3,883
Drives: Audi RS Q8
^ Doesn't gas go bad if you leave it unused for too long?
09-15-2008, 10:51 AM | #7 | |
20
Rep 368
Drives: 91' 850i
Don't mean to knock you, but of concern for your safety is there a way for you to keep that outside of the garage? I'd have a tough time feeling comfortable with that much gasoline in my garage. |
09-15-2008, 11:19 AM | #8 |
13
Rep 218
+1
[B]Electric Red/Black leather,aluminum, 6MT, sport package, 19" Beyer Multi Staggered Chrome rims/w BF Goodrich - g-Force T/A KDW (New Tread),debadged, fujita intake,muffler delete,rouge eng ssk,3000w alpine 12" sub/w 1000w alpine digital amp,smoked led tail lights. |
09-15-2008, 11:27 AM | #9 |
Dictator
55
Rep 1,811
I think the post might be b.s.
Nobody would store gasoline in their garage. It might even be illegal. (A friend of mine who used to live in Pacific Palisades raced vintage cars in Monterey. He had racing fuel stored in special safety drums which were stored outside in a cage, and with large decals he received from the fire department describing the contents......) |
09-15-2008, 11:29 AM | #10 |
72
Rep 1,217
87 will be fine for your engine. You may not get maximum performance or fuel economy, but it won't destroy your engine. Modern engines can adjust the timing to prevent the "knock" that everyone frets about. Engines have had this technology since the early 90s.
09-15-2008, 12:06 PM | #11 |
M-GAM3
240
Rep 1,264
Gas Go Boom. Would hate to be a young kid trying to hide behind your garage smoking a cigarette are a fire fighter trying to put out a fire not knowing there's 55 gallon's of fuel stored in the garage.
09-15-2008, 12:18 PM | #12 | |
83
Rep 634
As far as the gas goes... if you use a lower octane, you'll burn through it fast enough, it doesn't make a difference. It's like food & dieting... if you eat something once it's no big deal, but doing it over and over is where you run into problems.
ED & PCD = DONE & DONE! 08' AW/Coral 335i coupe 6-speed (Premium Pkg, Sports Pkg, Heated Seats) *European Delivery
09-15-2008, 12:44 PM | #13 | |
43
Rep 165
So what's the difference between gasoline in a 55 gallon drum and that in the tanks in the automobiles. |
09-15-2008, 12:59 PM | #14 |
Dictator
55
Rep 1,811
09-15-2008, 01:00 PM | #15 |
83
Rep 634
Yes, it's called a twisted or dark sense of humor. A kid sneaking into someone's backyard to smoke a cig behind a barrel of gasoline and getting blown up is funny.
09-15-2008, 01:35 PM | #16 | |
20
Rep 368
Drives: 91' 850i
Car's Gas Tank -Much lower chance of vapor leak -The tanks are enclosed by the car and won't budge, as opposed to a drum that can be tipped and damaged -There's only ~14 gal of it, usually less unless I fill up before I go home. 110 gallons of fuel is a lot of fuel, so I ran the #'s to add perspective. Explosion energy from 1 ton of TNT = 4.2 x 10^9 Joules Energy contained in 110 Gallons of Gasoline = 1.66*10^10 Joules My 2 cents |
09-15-2008, 01:59 PM | #17 |
v81 user
Rep 174
you guys are as paranoid about this as you are about your intakes losing 5 hp
2 55 drums is equivalent to two SUV's parked in a garage. They are VP Racing drums, they are designed for gasoline, they have a one way vent on them and are isolated in a corner of the garage away from any ignition sources. You put stablizer in fuel, it is fine. |
09-15-2008, 02:46 PM | #19 |
Rep 370
not in west knox, all that i can find is freakin low grade.
sadly knoxville was ranked highest in the country after this whole fiasco. ridiculous http://news.google.com/news/url?sa=t...1-W5jZPTi-vF6A |
09-15-2008, 03:21 PM | #21 |
21
Rep 437
But highly unlikely. Have you ever tried to light a container of gas? There will be an initial whoosh, and then just a plain boring fire. The gas will not explode unless there is an inordinate amount of oxygen mixed in there. Helluva big fire if the container is ruptured somehow, but nowhere near the energy potential in that gasoline without instantaneous access to oxygen.
09-15-2008, 03:24 PM | #22 | |
BALLER
19
Rep 626
+1 we keep backup gas in our garage as well... it's not 110 gal, but it's somewhat close.
no reason to freak out....it's equivalent of having a few cars in your garage.... Quote:
08 335cic Space Grey Saddle Brown Light Poplar Premium Sport Navi CA Cold HDrad Ipod Paddle PDC, L7, Auto 35%Ceramic
08 535i Space Grey Black Dakota, Premium, Sport, Navi, Cold, Sat, Auto, Ipod, PDC, AS, L7, 35% Ceramic 08 S65 AMG P3. Black on Black. Enough Said |
