Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions M Logo Coding In Default Instrument Cluster Tutorial
      04-09-2020, 04:26 AM   #1
g20beam
g20beam's Avatar
473
Drives: G20 330i M Sport
2019 BMW  [0.00]
Hello
To enable M Logo in default instrument cluster, go to DKOMBI4 and look for LOGO_SCHRIFTZUG, then select msp_logo.
Enjoy M Logo in default instrument cluster!
View screenshots for reference:
Appreciate 12
      04-09-2020, 07:19 AM   #2
JSaid
JSaid's Avatar
Drives: 2022 BMW M340i xDrive
Originally Posted by g20beam View Post
Hello
Wow, so VipinLJ was VERY close! Thanks for this, Ill be doing this during my lunch break
VipinLJ1941.50
      04-09-2020, 08:52 AM   #3
JSaid
JSaid's Avatar
I just added the M logo successfully, Thanks again g20beam
Anyone else get a little nervous every time the ECU restarts after coding? lol
Appreciate 3
      04-09-2020, 10:54 AM   #4
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I chose the m_logo instead of msp_logo since I didn’t want the M performance lettering (I thought msp was m performance). It didn’t work so I didn’t pursue it further. Glad g20beam posted this here.
Edit - Yes JSaid. I still get worried when the iDrive/live cockpit is restarting after coding.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Appreciate 2
g20beam473.00
JSaid286.00
      04-09-2020, 12:27 PM   #5
mmo011
Drives: BMW 320d MSport (G20)
No way for me :-( tried several time starting back from original backup with Bimmercode... tested M_Logo, Msp_Logo, more others... but nothing appear... M Logo appear only with M Style Cockpit that's not ok for my G20 320d-> 8k RPM and 330Km/h scale are too much higher :-(
      04-09-2020, 12:32 PM   #6
mmo011
what about the m stripes near the 0mph gauge into the picture? it's something stock or coded?
      04-09-2020, 12:40 PM   #7
VipinLJ
Petrolhead
VipinLJ's Avatar
That is present on 330is with the M sport package. I don’t have it since mine doesn’t have the pack. If someone could find out how to code that in, I’d be grateful. I like those subtle stripes and don’t mind those on the live cockpit
Current:
      04-09-2020, 02:20 PM   #8
mmo011
I have MSport Pack on my EU 320d but no stripes at all 😔
      04-09-2020, 03:52 PM   #9
hamzag20
hamzag20's Avatar
557
Drives: BMW G20 330i, BMW G30 540i
Worked great! Thanks g20beam ! Also JSaid I get hella nervous with those weird noises that are made too lmao when the ECU restarts.
Appreciate 3
      04-10-2020, 02:06 PM   #10
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
United Kingdom
443
Drives: BMW G20 330i RWD M Sport
I had never noticed this in my car so looked for it today. Found out that it shows in sport mode.......
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-11-2020, 11:53 AM   #11
Fpangalos
Fpangalos's Avatar
Drives: 2019 BMW 330i
g20beam473.00
      04-11-2020, 12:17 PM   #12
VipinLJ
Petrolhead
VipinLJ's Avatar
If any of you ever figure out how to code the tri color stripes next to the 0mph on the LC, please post that here. I searched but couldn’t find anything that made sense to me.
Current:
      04-11-2020, 12:36 PM   #13
g20beam
g20beam's Avatar
473
2019 BMW  [0.00]
Originally Posted by VipinLJ View Post
If any of you ever figure out how to code the tri color stripes next to the 0mph on the LC, please post that here. I searched but couldn't find anything that made sense to me.
You have to change your car's info from a Sport Line to an M Sport line in DKOMBI4, there's some lines in there that differentiates M Sport models from Sport Line.
VipinLJ1941.50
      04-11-2020, 12:41 PM   #14
VipinLJ
Petrolhead
VipinLJ's Avatar
I assumed that was it. The reason I didn’t want to do that was because I think that might change the pic of the car on the LC to an M sport pack car while mine is the sport line. Guess I’ll have to live without the stripes then
Current:
      04-11-2020, 02:16 PM   #15
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Hi, Does it work on Alpina Cluster as well?
hamzag20 How did you get the G meter showed up ?
      04-11-2020, 02:49 PM   #16
VipinLJ
Petrolhead
VipinLJ's Avatar
It should work on the alpina cluster too since that option is present.
And the G meter is already present. Press the BC button on the indicator stalk to go through the various menus and you’ll see the G meter pop up there.
Current:
hamzag20557.00
      04-11-2020, 07:40 PM   #17
hamzag20
hamzag20's Avatar
557
What VipinLJ said
VipinLJ1941.50
      04-12-2020, 02:00 AM   #18
g20beam
g20beam's Avatar
473
2019 BMW  [0.00]
No it actually won't, the modules are separate, the car in the IC and the control display can be selected regardless of the Sport Line or M Sport configuration. I know this because I tried changing the trim and colour of my car in the iDrive control display and the IC changed as a result of the change made to the control display.
VipinLJ1941.50
      04-12-2020, 02:19 AM   #19
MY86
MY86's Avatar
Turkey
15
Thanks for the reply. I have a 2019 M Sport 320i from Istanbul / TR and the G meter does not pops up the way you said Is there anyway to code the G meter via BimmerCode?
      04-12-2020, 07:02 AM   #20
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
On my M340, the tri-color diagonal striping by 0 mph, only shows up in Sport mode.
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
MAGugs1.50
      04-12-2020, 08:17 AM   #21
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
Do you have MGU id7 head unit? I think G-meter might be unlocked in MGU, because yesterday I found G-meter maximum value code in MGU. Parameter is G_METER_MAX_VAL. Default setting for my 320d is 0,8g. Maximum setting is 2.0g. Maybe activation code somewhere in MGU like a code for sport displays in old F30.
This is strange that you don't have g-meter if you have MGU unit, cause in Russia I have this from factory.
Off top: do you have plastic headlight covers under the hood 51767499927 and 51767499928? I found that Bmw don't install it on cars that supplied to Turkey and Russia. Strange thing for me. Price of this plastic covers is 10 $🤔
      04-12-2020, 09:58 AM   #22
MY86
MY86's Avatar
Turkey
15
Off top: do you have plastic headlight covers under the hood 51767499927 and 51767499928? I found that Bmw don't install it on cars that supplied to Turkey and Russia. Strange thing for me. Price of this plastic covers is 10 $��
Hi, yes I have the ID 7 Head Unit. It is weird that none of the cars have the G meter thing over here. We only have 320i's at the moment. Maybe, it will be available on 330i's but it is still weird. I will try changing it to 0.8g to see if it works. Thanks for that.
I did not heard of that plastic headlight cover thing before. I will check it for you and reply.
g20
