04-08-2020, 06:20 AM | #1 |
179
Rep 565
weight training advice?
so I keep generally fit through circuit trainning, tennis running and cycling. Looking ahead if we end up not being able to go out for exercise at all that will send me bonkers. I'm not gym person but have some dumbbells never really done much with them.
So I thought I'd dust off the dumbbells during this current situation and in readiness for if I cant exercise outside Ill need something else. So a proper program I can stick to is what's needed. something that is progressive. The missus is all excited as she thinks I'll look like some chiseled Adonis in 3 weeks. She has found me this. https://www.coachmag.co.uk/fitness/w...bbell-workouts What we don't understand is do we do work outs 1 2 3 and 4 spread out once across a week then up the reps and sets or does a "session" include all 4 workouts after each other - doing all 4 say 3 times a week? Got through workout one last night and all was good. Any advice thankfully received. |
04-08-2020, 06:40 AM | #2 |
103
Rep 161
You do them one at a time spread out over the week. As it's effectively a 4 day split... I would normally do Monday&Tuesday training, Wednesday rest day, then Thursday&Friday training, rest over the weekend.
If you could get hold of a bench you'd be able to achieve a lot more... but they are probably gold dust at the moment. I'd also question the effectiveness of splitting it up in to specific body parts for a home dumbbell workout. It might be more beneficial to find a workout with upper and lower splits. Especially as you are a beginner, you might see better results with that. I'll see if I can find you something. The leg workout didn't have anything focusing on hamstrings, I'd be throwing some dumbbell RDLs in. |
flashollie178.50 |
04-08-2020, 07:23 AM | #3 | |
179
Rep 565
If you could find something that would be great much appreciated. my legs are generally strong from running and cycling. What are RDLs? I could knock up a bench from a scaffold plank and a couple of small stools? |
04-08-2020, 10:33 AM | #5 |
10998
Rep 32,881
When starting out there's no need for splits, better to start with full body workouts 2 or 3 times a week, then after a few weeks when you don't have DOMS anymore then change to upper/lower body splits. Push/pull/shoulders/legs splits aren't needed until at least 6 months of training really.
Other most important advice I'd give is always go to failure on every set, and always lower the weight slowly on every rep. |
04-08-2020, 11:27 AM | #6 | |
17519
Rep 25,128
I'd avoid dumbell press ups if a beginner, renegade rows yes but myabe not initially pressing on a mobile dumbell.
My car made front page of Bimmerpost
04-08-2020, 12:04 PM | #7 |
179
Rep 565
Thanks very much for all the responses.
I'm fairly fit guy doing 2 x hours of circuits a week so press-ups squats burppes and many many other body weight exercises. Only have mild DOMS after the chest and back session yesterday. Finished the arms one at lunch time. I take the point about not splitting the work outs yet and will have a crack at using the exercises I originally linked 3 times a week. I'll rest tomorrow and pick it up Friday. |
04-08-2020, 12:14 PM | #8 | |
10998
Rep 32,881
Concentrate on those eccentric overloads. There's a great saying; it's not about counting reps, it's about making every rep count. |
04-08-2020, 01:15 PM | #10 | |
10998
Rep 32,881
5kg dumbells would maybe do for shoulder side raises, but not much else. 10kg is probably the lowest useful dumbbell weight, but selectable ones of at least 25kg ideally. |
04-08-2020, 02:29 PM | #11 |
2287
Rep 4,937
Google some hiit with weights work outs as well. Joe wicks has a good one 25min full body hiit with weights.
I have my setup in the garage now and am considering a cheap squat rack if we are house bound for a few more weeks. |
04-08-2020, 02:52 PM | #12 |
10998
Rep 32,881
I would say don't combine cardio and weights, both end up being compromised. Advice is actually not to do cardio less than 8 hours before weights workout.
04-08-2020, 02:56 PM | #13 | |
17519
Rep 25,128
04-08-2020, 03:12 PM | #14 | ||
179
Rep 565
Is the idea that by doing splits your doing quality not quantity? |
04-08-2020, 03:33 PM | #15 | |||
17519
Rep 25,128
For example you might do squats for legs in an all over body program 2-3 days a week. With a 'Leg Day' you might do squats, dead lift, lunges etc etc etc for 40-60 minutes. There are so many variables hard to explain all briefly but that's the premise of days working on specific areas. Other approach has you doing push pull days etc Lots of ways to train!
04-08-2020, 03:35 PM | #16 | |||
10998
Rep 32,881
Typical full body workout: Pull ups = lats and biceps Bench press = chest and triceps (& bit of front delts) Seated rows = mid back and biceps (& bit of rear delts) Shoulder press = mid delt and triceps Squats = upper legs (& bit of lower back) Typical split day for chest and triceps: Bench press Dumbell flyes Decline/incline dumbell press Barbell tricep extensions Cable tricep pulldowns The full body workout you could do 2 or 3 times a week, the split ones will need a week recovery before you work that muscle group again, but there are 4 groups of muscles so it is 4 workouts a week. |
04-08-2020, 03:39 PM | #17 | |
2287
Rep 4,937
Yes if you want to have weight days and then cardio that works well but add in a hiit like that and it shocks your muscles in a good way. |
JustChris17518.50 |
04-08-2020, 03:45 PM | #19 | |
10998
Rep 32,881
When I haven't trained for a few months (which is very often these days ) I always do upper/lower body splits. |
04-08-2020, 03:49 PM | #20 | ||
10998
Rep 32,881
04-08-2020, 07:22 PM | #21 | |||
103
Rep 161
teaston10998.00 |
04-09-2020, 12:06 AM | #22 |
124
Rep 298
I tried the HIIT sessions but found I was giving myself too long for rest periods, so bought a DVD I could follow. Firstly as I didn’t really know what I was doing so I could see technique but also get my timings right between work & rest.
I’ve been using Body Beast for about 18 months and while I’m a very long way from looking like the instructors, results have been good and everything has a bit more shape and is a lot firmer. It’s designed to be done at home and I started with a cheap dumbbell set and a kitchen chair, worked ok. Now bought a set of rubber hex dumbbells and a proper bench and it is less hassle now. I’m still enjoying it. Sessions are between 25-45 mins so I can get one in while dinner is cooking. If you’re looking to tone up a bit I’d recommend any dynamic set training DVD. There will be loads on eBay or amazon. |
