BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Flickering side markers and license plate lights
      04-06-2020, 03:07 PM   #1
haaken675
101
Drives: 24v turbo e30, e92 335i
Hey everyone. I recently acquired an '07 335i and have been slowly fixing all the issues that the PO created. One of the most recent I need to tackle is a lighting error. I get a light bulb error being thrown on the car periodically when driving. What I have noticed as well is that the license plate lights will flash/flicker randomly at time, and I just noticed yesterday that the side markers are doing that as well. These units have been replaced with LED ones of unknown origin. I understand that without the proper resistance the car could throw an error code, but what could cause the lights to just flicker on their own?
      04-07-2020, 10:35 AM   #2
matteblue3er
238
Drives: Racecar
Bulb check. Code it out. Look in coding section
      04-07-2020, 11:45 AM   #3
haaken675
101
I understand I can code out the error. Its the fl9ickering im trying to get rid of. Are you saying that the error code generated by the ECU is causing the flickering of the lights?
      04-08-2020, 09:57 AM   #4
matteblue3er
238
Drives: Racecar
The bulb check will quickly pulse the bulbs to check for operation. A traditional filament bulb will have a certain resistance if it's working. LEDs do not have the same resistance the FRM is looking for.
When LEDs are installed, this pulse results in a few quick flashes from the LEDs.
Disable the warm check to disable t he check while the car is running.
Disable the cold check to disable the check upon switching ignition.
      04-08-2020, 10:52 AM   #5
haaken675
101
I hadn't thought that it would be something that could be coded out. Had my buddy come over last night with his Carly adapter and we turned everything we could find off, and so far it looks like we took care of the issue. Thanks for pointing me in the right direction.
      04-08-2020, 01:17 PM   #6
ewicky
Drives: '07 335xi 4D AT
Just replace the shitty LEDs with real light bulbs and be done.
      04-09-2020, 11:38 AM   #7
haaken675
101
Why spend the money if I don't have to? I would have had to order new side markers entirely, new license plate lights, etc. as the previous owner had already changed them. Either way, its fixed now...
      04-13-2020, 03:21 PM   #8
matteblue3er
238
Drives: Racecar
Not to mention ALL LEDs will exhibit this behavior. It is dependent on the light source technology, not the quality.
These quick pulses are too fast for a filament bulb to light up so you don't see the flickering. For LEDs, since they are instant on, you see the flashes.
