04-06-2020, 02:34 PM | #1 |
Joint Chiefs of Staff
24198
Rep 190,807
VRSF B46 / B48 Charge Pipe Now Available! *** NEW PRODUCT ***
VRSF Charge Pipe Upgrade Kit for your 2016+ F & G Series 120i, 125i, 220i, 230i, 320i, 330i, 420i, 430i, 520i, 530i, 630i, 730i, X3 20i, X3 30i, X4 20i, X4 30i, X5 30i, X6 30i & Z4 30i BMW with the B46 & B48 engine. Increase throttle response and decreases turbo lag with the VRSF Charge Pipe Upgrade for your F or G Series BMW with a B46 & B48 engine. Please refer to the chart below for exact fitment. Every VRSF Charge Pipe is constructed from mandrel bent, T6061 grade aluminum including the flanges. Each flange is precision machined from CNC billet aluminum, including the throttle body, intercooler and vacuum connections. After these are welded, theyre test fitted on multiple jigs in order to ensure proper fitment and a reliable, leak free connection. Each VRSF charge pipe is finished in a durable wrinkle black powder coated finish that blends in perfectly with the engine bay. We also include two plugged 1/8″ NPT bung that can be used for methanol injection, boost leak testing or as a boost source. The OEM charge pipe is prone to failure at both stock and tuned boost levels which is why we include everything necessary to replace your flimsy OEM chargepipe including high quality, 4-ply silicone couplers as well as stainless steel t-bolt clamps. Additionally, we offer and recommend replacement throttle body c-clips and o-rings in case your original clip and gasket are lost or worn. Features:
This item fits the following BMWs:
04-06-2020, 08:43 PM | #3 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Nowhere in this post was there anything mentioned about power gains. You get a better throttle response is your gain. Plus a couple things already mentioned. But power gains was not one of them.
04-07-2020, 11:10 AM | #4 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,208
04-07-2020, 11:13 AM | #5 | ||
2314
Rep 2,885
04-07-2020, 12:48 PM | #6 | |||
3511
Rep 4,208
04-07-2020, 02:41 PM | #7 | |
2314
Rep 2,885
lol. And FTP is back to the drawing board. Shoot me a DM and Ill tell you all about it if youd like. But im done with the thread jackin here. srrryy.
