04-05-2020, 12:09 AM | #1 |
242
Rep 765
searching for springs, M3 compatibility
I'm searching for used springs and trying to widen my search a bit. since oem M3 springs fit the F30, it should be safe to say that aftermarket springs should fit also? seeing some used lowering springs on the F80 M3 board.. would the drop just be more or about the same as the spring lists for its application? I would also imagine the spring would be a bit stiffer than whats advertised because of the vehicle's weight difference..
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-06-2020, 12:52 PM | #2 |
5886
Rep 10,256
How many miles does your vehicle have? Shocks usually reach the limit of their useful life before springs do.
If the shocks need to be replaced in the near future, coilovers (shocks + springs -> designed for your car) would be a good alternative. |
04-06-2020, 01:27 PM | #3 | |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
As for the spring rates, there are a good amount of lowering springs for the F8x that are stiffer than the F8x base suspension, but less than competition pack suspension. You'll want to keep this in mind since you may be reducing your damping factor a good amount. This is typically why people think their stock dampers "went bad," because they've already reduced the damping by going to strong springs, and thus get closer to the point where things feel underdamped.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-06-2020, 02:04 PM | #4 | ||
242
Rep 765
04-06-2020, 02:15 PM | #5 |
5886
Rep 10,256
DreamerJoe, thanks for the details.
I had the same car as yours in the past: 2013 F30 335i. After exhaustive research, I decided to install KW Street Comfort coilovers (about $1.6K). Was very satisfied with this product. |
