04-04-2020, 05:17 PM | #1 |
9
Rep 55
What is the flap inside the left exhaust pipe?
I have a 2019 X3 30i, and noticed that the left tail pipe has a flap about half a foot inside. I don't see on on the right tail pipe.
Thoughts on what this is? |
04-04-2020, 06:16 PM | #2 |
336
Rep 1,642
well spotted!
Pretty hard to actually see that that valve when you need to It's a valve that stays closed when you start the engine to help the catalysts (?) warm up faster and produce less pollution. I believe it's electrically controlled. I think it also stays closed much of the time when you drive, to reduce exhaust noise and 'drone'. It opens on full throttle Search for plenty of threads to disable this valve so it remains open all the time (for better/louder exhaust sound)...though that could result in a drone at highway speed
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
04-04-2020, 06:18 PM | #3 | |
9
Rep 55
04-04-2020, 06:57 PM | #5 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,208
Put it in sport. It opens the valve. For 100% always open pull the fuse or the connector when it's open.
04-04-2020, 08:19 PM | #6 |
1910
Rep 5,105
Fuse # 203 in the trunk, right hand side panel.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
04-05-2020, 11:29 AM | #7 |
97
Rep 399
Drives: 2023 BMW i4 eDrive40
Will disconnecting the connector throw a Fault code
If I disconnect the connector or remove the fuse, will a computer throw a fault code and/or set off the CEL?
Thanks Wallyf |
04-05-2020, 02:24 PM | #8 | |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Some members even took their cars in for BMW service with the fuse removed. I wouldn't recommend that. Heres a quick guide. Different exhaust sound since its a M but same steps and concept.
04-06-2020, 06:54 PM | #9 |
336
Rep 1,642
I haven't tried this yet as I recall reading a couple of posts where they found that even when they replaced the fuse, the exhaust sound wasn't as loud as before?
Also some concern about the valve being stuck closed for example due to vibration (I guess due to no power getting through as fuse has been removed)? Incidentally, is it Sport mode or only Sport Plus that apparently keeps the valve open?
04-07-2020, 11:09 AM | #10 |
3511
Rep 4,208
Nobody at the dealer cares that the fuse is removed. Even if they see the fault they won't care. Unless you're complaining that the exhaust is making a weird noise or something directly related to it. Just FYI. Coming in with a tune on the other hand, they don't like that so much.
chicagofan0019146.00 BMWZ41909.50 |
04-07-2020, 04:28 PM | #11 |
1313
Rep 1,064
I went in for an oil change at the dealer; they had to put fuse 203 back in to update the blah blah blah, but then they actually pulled fuse 203 again for me before I picked it up.
I usually leave fuse 203 pulled, unless I'm on a long road trip or with lots of people in the car. |
04-07-2020, 04:32 PM | #12 | |
1496
Rep 841
04-07-2020, 06:22 PM | #13 | |
19146
Rep 8,032
Drives: 2024 X5 M60i
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
