N53 crickets
04-04-2020, 03:24 PM | #1 |
102
Rep 681
N53 crickets
Hi
I know the n53 is known for a rough sounding idle compared to say the N52 and that the noise / clatter is the piezo injectors and the HPFP solenoid. There is another noise that sounds like brake disc rubbing slightly, like a high pitched crickets in the distance type sound. Maybe that's just the solenoids etc but has anyone managed to either quieten it down or drown it out with a louder exhaust or intake mods? Thx Mike |
04-05-2020, 05:58 AM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Hard to tell which noise you're referring to without a soundtrack. Depending on miles covered, the rubbing sound could be serpentine belt/pulley/tensioner...
But you're right, the N53 isn't quiet (still a great engine though IMHO). One thought - if your car isn't fitted with the under-bonnet blanket (or it's worn out) worth considering this to reduce underbonnet noise. Also the noise-absorbing foam under the cosmetic cylinder head cover tends to deteriorate with time.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
