04-04-2020, 01:38 PM | #1 |
Rep 14
F30 LCI rear sensor wiring
Hey,
I have a problem with the rear left wheel speed sensor. All sensors show the same speed, except the rear left which shows zero km / h. As you can guess, I have errors on my dashboard and my esp and abs does not work. I realize that both the sensor and the wheel bearing may be at fault, but I must first check the beam (colision in the past). Can somebody share a wiring diagram for rear left speed sensor? Is it connected directly to the abs driver? Is anyone able to point out pins? Thank you in advance for your help. |
