BIMMERPOST Universal Forums Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..)    Don't write off the old prancing pony
      04-02-2020, 07:20 PM   #1
msk340i
1320
Drives: 340i M sport
A lot of us earthlings mocked Ferrari's engineers and how they are behind after the whole DAS thing. This article shows that they're still using the muscle between their ears.
https://www.motorsport.com/f1/news/p...efits/4775662/
M5Rick60062.50
      04-02-2020, 07:27 PM   #2
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
Prancing Pony kind of sounds like "Prancercise" MK, you're up.
FTR I love Ferrari, I'd buy one if I could afford one....I have to stick with Porsche and hope that they get into F1 so I feel validated.
      04-02-2020, 07:40 PM   #3
yco
i'm just saying
yco's Avatar
5738
Drives: E71 X6M '10 (sold)
DAS is double axis PAS is power assist..
it sounds more like comparing apples and oranges except they re both fruits.. but by PAS since there wont be a secondary axis, ackermann angles cant be changed anyway for slower corners.. and it doesnt look that hard to adapt like DAS do.. we d really see the DAS' benefit in Monaco especially on tight U turn and chicane but we wont able at all since it ll be banned next year..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
      04-02-2020, 07:47 PM   #4
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
63358
Drives: ///M3-E92-DCT Silverstone II
Porsche is the best sports car ever made .Ferrari is crap .
While I'm dreaming from a 911 (992) Turbo-S
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
Appreciate 2
M5Rick60062.50
Murf99314114.00
      04-02-2020, 09:18 PM   #5
msk340i
1320
I love my Porsche what are you talking about?
      04-02-2020, 09:26 PM   #6
msk340i
1320
What I understood is PAS has "2 rack-and-pinions" and that can produce an adjustable Ackerman angle on tight turns which is actually more beneficial than DAS. DAS can only produce the same angle on tight and wide turns on the other hand.
That tells us that Ferrari are onto the benefits of a steering system with variable toe angles/Ackerman angles. Mercedes' solution leaves it to the driver whole Ferrari's solution leaves it to the double rack-and-pinion.
Side note: every time I read about DAS explained by engineers (Mercedes and other) they always say that DAS's main advantage is on the straight not as most people think that it's for the turns. Because DAS produces a zero toe-in and that decreases resistance on the straights. That made them mention high speed circuits not low speed ones like Monaco.
      04-02-2020, 10:00 PM   #7
..Rush..
..Rush..'s Avatar
Drives: AW E88
P O R S C H E = There is no substitute.
      04-03-2020, 02:29 AM   #8
M5Rick
M5Rick's Avatar
60063
Drives: M5 F10 DCT Gunmetal
Wow all this steering wonder-esy has got me all in a tizzle
      04-03-2020, 02:35 AM   #9
M5Rick
M5Rick's Avatar
60063
Ferrari commanding huge prices even the old 246,308's and Dino's that are bits in boxes.
      04-03-2020, 02:55 AM   #10
yco
i'm just saying
yco's Avatar
5738
"The W10's power steering arrangement was equipped with a double rack and pinion setu-p, creating a variable Ackermann system that made it possible to make one wheel steer independently of the other, depending on the given steering input."
i guess this part, answers some of your questions about 2-rack and on..
about DAS.. actually the point is, may sound a bit geeky but not like 0 toe, if you set a car for a bit toe-out on front and toe-in on the back thats the ultimate way for free flow on the straights and stability.. Indy cars use it for example.. makes things better for initial part of the corner as well by this..
and if you re not fantasizing with caster especially, having toe-out more exaggerated will help reduce understeer and if your car is grippy on front it ll give pointy front end mechanically if your rear of the car is grippy to handle that.. this concept was already with W10 maybe even backwards.. and almost of the race cars ultimate goal.. cause by this you give less steering effort to take the front wheels off the center.. so with this in mind, DAS helps to concentrate much more corners without compromising straight line alignment for less scrub since you can change them..
for high speed tracks and tracks like Monaco part.. its not about high speed tracks.. its all about straights.. before DAS you had to think about the straights as well.. but by DAS you have more room to play with alignment since you can neutralize your cornering setup on the straights.. i suggest you to watch first few laps of Bottas in pre-season testing, how car acts weird when he was moving the steering wheel on wrong times.. basically we re telling almost the same thing.. what Merc' engineers are telling is this also except with the hidden part.. they re not telling that we dont need to think about straights anymore cause they can now eliminate cornering setup on straights.. race cars adjusted to corners not straights.. the reason why we have DRS.. though there are exceptions like Monza.. cause most the lap is full throttle without not much lateral force teams set their cars to low drag.. and when you think about best teams on speed traps tends to struggle in Parabolica.. cause they re thinking more for the straights with less downforce..
for ackermann part.. and after lets say after putting 5-6 degree of steering angle its totally different affect on the car than basic toe-in or out.. ackermann becomes important on really slow corners that not much aerodynamic factor is in play anymore.. like the slowest corner of the season U turn in Monaco and the chicane.. and Monaco is the track we see most anti-ackermann setup on entire calendar and front toe adjustment of course + camber.. to achieve the optimal slip angle on slow mechanical corners.. the less vertical load a tyre has, the lower the amount of slip angle it can sustain.. and actually thats why i was wondering how high could Merc' fly with DAS in corners since they could change the geometry for the straights.. that was my point.. cause they wouldnt need to think for the straights anymore.. and this is why Merc' engineers came up with this idea.. having more room to play for corners and shred more time in corners without thinking for straights anymore when they want..
for PAS.. this part of the article..
"Having the ability to vary the Ackermann angle depending on the corner's profile can have some interesting aerodynamic implications."
well ackermann angles varies depending on how much steering angle you put already.. and this part states the difference between DAS and PAS.. though name the PAS is a bit blurry for me.. cause power steering is already been in use for many years in F1.. its not that clear like DAS.. and without thinking of the initial toe setting is only telling half of the story of ackermann setup as well on the other hand..
While PAS is not as advanced as DAS, it was this type of system that Mercedes first began running from the start of 2019 and became the precursor to what it has developed for this year.
as i ve said, it doesnt look hard to copy for other teams.. which it doesnt make PAS less better or something.. its good to see Ferrari is working on stuff except just firing people..
and im pretty glad that we can have chance to talk about technical part of F1 here as well..
      04-03-2020, 04:30 AM   #11
msk340i
1320
Thanks that clarified a lot!
yco5737.50
      04-03-2020, 06:40 AM   #12
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
Me too, but this is stunning.
Appreciate 2
M5Rick60062.50
      04-03-2020, 06:44 AM   #13
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
[QUOTE=msk340i;26001533]I love my Porsche what are you talking about?[/QUOTE
I do love my Porsche.
Appreciate 3
EdM54066.00
M5Rick60062.50
      04-03-2020, 08:01 AM   #14
M5Rick
M5Rick's Avatar
60063
Those Borani spoked wheels look the biz with the winged knock ons.
Appreciate 2
      04-03-2020, 08:08 AM   #15
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
I've always been a Ferrari fan, the vintage ones are just rolling art though.
M5Rick60062.50
      04-03-2020, 08:11 AM   #16
M5Rick
M5Rick's Avatar
60063
That's right, putting the brakes on some of them you had to pray they didn't fade.
Appreciate 2
      04-03-2020, 10:26 AM   #17
msk340i
1320
[QUOTE=Murf993;26002396]
I don't know how to attach a picture but my '86 Targa it's nothing next to your beauty 😍
      04-03-2020, 10:52 AM   #18
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
[QUOTE=msk340i;26003072]
I don't know how to attach a picture but my '86 Targa it's nothing next to your beauty ��
Hit the Quote button at the bottom, and then use the paperclip on the top tool bar. This will open the upload tool. Attach your image and then you have to add some text to the body. And then Save.
      04-03-2020, 10:54 AM   #19
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
Porsches are all beautiful.
Appreciate 2
      04-03-2020, 10:57 AM   #20
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
[QUOTE=Murf993;26003191]
Hit the Quote button at the bottom, and then use the paperclip on the top tool bar. This will open the upload tool. Attach your image and then you have to add some text to the body. And then Submit Reply on the bottom.
      04-03-2020, 11:04 AM   #21
M5Rick
M5Rick's Avatar
60063
[QUOTE=Murf993;26003197]
Have one myself but not a 911..it's an '83 928S 300bhp.
Needs a bit of work mechanically but repainted the bad bits myself and after changing fuel filter will be firing it up soon when warmer.
Can't do a pic as covered up.
      04-03-2020, 11:07 AM   #22
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
[QUOTE=M5theonlyone;26003242]
The 928S isn't everyone's cup of tea, but I think they are a damn sexy car. I badly wanted one back in the day. They still catch my eye on the rare occasion you see one.
