03-31-2020, 10:51 PM | #1 |
67
Rep 113
BMW B14 PSS Coilover Kit
Whos using this setup. I have been searching on google, and found it hard to find very many good, in depth and even some longer term reviews on this setup for the F30....ive seen many for the E90/E92 but not so much on the F30.
Would def like F30 specific comments, concerns, longer term use, your local road conditions, road trips taken with them etc. here in vegas we do have shitty roads, and unfortunately where I travel to on a daily basis the roads i have to use arent the best in the valley. Gonna pull the trigger on a setup before summer, and debating on springing $1044 for these, or saying fk it and get BMW Coilover Kit - Sachs Performance 841500000441.... EDIT: B16 PSS10 Coilover System ARE AN OPTION AS WELL, FCP doesnt sell it but does say limited lifetime warranty My requirement is that they come from FCP euro, because they are easy to deal with, and lifetime no questions asked warranty and these are the only 2 coilover options they offer (besides the BR setup, which ive seen mixed opinions on) Dont mind my skeptical mindset on coil overs, because when I had a coilover setup on my E38, i had KIDO coilovers, and they were shitty....yes you get what you pay for, but they didnt last long which possibly came from a combo between cheap, not majorly engineered, and or on a much heavier car....while i can afford a good setup, I cant afford to have a shitty product and have to replace it twice. Last edited by sigtwenty; 03-31-2020 at 11:09 PM.. |
04-01-2020, 05:55 PM | #3 |
Dü Werke
420
Rep 87
I ran the B14 for a little less than a year, but came away with the two impressions below:
#1: The dampers seem VERY firm - sharp impact from most bumps and expansion gaps were common in my experience. Mid-corners bumps also seemed to slightly upset motion of the car with this setup. Ambient temperature also seemed to have a mild effect on this behavior: a bit more tolerable in summer, but borderline too harsh in winter (around -5C). #2: The springs feel un-matched to dampers (mainly, soft feeling rear springs) - wash-board roads created a subtle, but uncomfortable front to back waddle sensation on my car. Again, this is only my impression/ opinion. I ended up going with M-performance suspension afterward which (still, dampers are a bit harsher than I would like for a daily) was a great improvement over the B14. |
alohasurftoad3081.50 |
04-01-2020, 06:55 PM | #4 | |
4016
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
The "waddle" sensation you experienced is due to the front ride frequency being higher than the rear, which makes it so the car takes longer to settle over road features. The OE suspension and M-performance suspension spring rates have flat ride, which has a higher rear frequency than the front to help the car settle faster.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-01-2020, 11:59 PM | #5 | ||
993
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
04-02-2020, 12:52 AM | #6 | |
4016
Rep 3,540
04-02-2020, 01:04 PM | #7 |
55
Rep 77
Yep, it's a relatively simple and inexpensive swap to change the rear springs on B16s. Increasing the rear spring rate was a significant improvement over the Bilstein springs, and I think it works reasonably well with the dampers. More details on this thread as well.
04-10-2020, 01:37 PM | #8 |
99
Rep 132
Is this what you are running? Any other experiences?
Was looking at the B14 cause im cheap, but I don't want to be unhappy. My car is stock 335i rear drive m-sport static suspension It feels very under damped and floaty when pushed at all. Need to get it under control but I don't want a really harsh ride either. I used to have bilstein sports on bav auto sport springs on my old e36 convertible. That car handled a lot better than my f30 despite being a vert. Any real life experience apprieciated |
04-10-2020, 02:00 PM | #9 | |
3082
Rep 4,331
while bilstein is a great entry coilover however after reading FaRkle!'s many tests and reviews, the internal bumpstop seems to be its weak point and the front spring rate too stiff. bilstein tends to have a firmer ride that's more performance oriented, whereas KW is more comfortable for street. another option is to do a damper/spring combo (non height adjustable). Koni SA or Yellow with Eibach springs seems to have the best reviews. member @johnung has Koni SA with Eibach springs and it sounds like something you'd like. Koni Yellow has a rebound adjustment at the top for fine tuning. Last edited by alohasurftoad; 04-10-2020 at 02:05 PM.. |
04-12-2020, 02:54 PM | #10 | |
67
Rep 113
im not looking to track the thing, but i do want it to be a little better planted to the road, and still be decent enough for a road trip while closing off the wheel gap to give the car a much better apperance. Last edited by sigtwenty; 04-12-2020 at 03:09 PM.. |
04-12-2020, 03:59 PM | #11 | |
3082
Rep 4,331
the terms better and reliable are subjective and difficult to answer objectively. my opinion is based on the many threads/post/reviews i've read here so take it FWIW. if you go with damper/spring combo, at this point in time, Koni SA or Sport Yellow are better dampers and Eibach a better lowering spring than B8+H&R for the street. Bilstein monotube has high gas pressure resulting in firm ride and i've noticed more reverse rake with H&R spring set ups. if you prefer and are informed about B8+H&R and rather this instead, that's fine also. query @johnung as he is very informed about Koni's. in your 1st post, you stated B16 was an option. this might be good option because you can adjust compression and rebound easily, as well as set your desired ride height. here's a good thread on it...https://f30.bimmerpost.com/forums/sh...t=bilstein+b16 M-performance suspension can be found at more reasonable prices than a few years ago. you can assemble it off the car and do a complete swap. it's way more planted than m-sport, albeit slightly firmer and just 10mm lower. KW V1 preset ride, it can go pretty low, more comfortable than bilstein for street. @thatBimmerBloke just did a ton of research before getting these. query him for good info. Last edited by alohasurftoad; 04-12-2020 at 05:19 PM.. |
