BMW X5
      03-31-2020, 07:52 PM   #1
:chesmu:
Drives: BMW X5
air intake modifications?
Anybody see any threads on air intake replacement/modifications?
      04-01-2020, 11:57 AM   #2
AnOldBiker
Jim
AnOldBiker's Avatar
Drives: 2019 X5 XDrive 40i
I'd like to find some to
      04-04-2020, 07:07 PM   #3
:chesmu:
Drives: BMW X5
The airbox looks like PIA to get into. At the very least I'd like to drop a K&N filter in there. But the screws look difficult to get too/easy to drop into the engine bay
      04-05-2020, 02:08 PM   #4
AnOldBiker
Jim
AnOldBiker's Avatar
Every BMW box I went into, the screws unscrewed, but never left the tabs unless you make them. Just unscrew, lift the box lid, change to filter, install box and align the screws to the holes.
      04-05-2020, 02:16 PM   #5
:chesmu:
Drives: BMW X5
Yeah. I see what you're saying. That sounds like abetter plan than removing the screws altogether. I've done it on my 330 andX6, but bith those airboxes were easier positioned to get to. This one's all angled downward and tucked in close to the front of the engine compartment. It's like playing "Operation". Takes a steady hand...
      04-05-2020, 06:20 PM   #6
888RRE
Australia
60
Drives: 2020 X5 M50i
Ihave done extensive research on this and even contacted a company in the states who do alot of BMW intakes, nothing from their end yet as it is so new. They are developing something.
The next best thing would be to take the standard filter out and try compare with an existing K&n product then install that.
      04-18-2020, 12:45 PM   #7
mikestpierre
Drives: F98 - X4M Competition
I quite easily removed the intake cover/filter and installed a BMS high-flow intake. In all it took about 30 minutes, didn’t damage anything, and the turbos are noticeably louder when they spool up.
I installed a JB4 and new plugs at the same time, maybe an hour under the hood.
Edit: Photo Attached
Appreciate 2
cptcolo102.00
      04-18-2020, 12:47 PM   #8
mikestpierre
Two of the screws are a little tricky, but when backing them out I just stopped using a driver and used my fingers, easy to not drop them.
      04-18-2020, 01:54 PM   #9
AnOldBiker
Jim
AnOldBiker's Avatar
Was there any benefits from converting to the BMS ?
Outside of easy filter change.
What year is your car ?
      04-19-2020, 03:09 PM   #10
mikestpierre
Other than the louder turbo spooling I couldn’t really tell you. It’s a 2019.
I put the JB4 in at the same time, so I wouldn’t be able to know if it had more of much of an impact.
It does sound great though...
cptcolo102.00
      04-19-2020, 08:07 PM   #11
CMBX23
CMBX23's Avatar
Drives: 20' 540i M Sport
2020 540i  [0.00]
Anyone know if the BMS intake is compatible on a 50?
      04-20-2020, 08:54 AM   #12
AnOldBiker
Jim
AnOldBiker's Avatar
Here's their contact webpage.
https://burgertuning.com/pages/contact
I'd email them, and if they say yes, and it doesn't fit, you'll be in a better situation when returning it.
CMBX2348.00
      05-09-2020, 06:19 PM   #13
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
So there are no intake options for the M50i?
2013 X6 - retired
2015 X6 - retired
2015 435GC - retired
2018 X5 40e - retired
2020 X5 M50i - Current
      10-17-2021, 07:48 PM   #14
ysuee
Drives: 21' X5 40i
BMS Air intake for X5 40i G05
Thanks for uploading those photos. What was the part number for the air intake you purchased from BMS? I'm asking because I have a '21 X5 40i that I'm looking to add a JB4 and an air intake to. I sent an email to BMS for both of those and here was their response:
Thanks for reaching out.
That is the correct JB4, yes. Unforutnlety, we do not offer a G/X5 compatible intake.
Any other questions just let us know.
https://burgertuning.com/collections...oducts/b58-jb4
Best,
Burger Motorsports Sales
BurgerTuning.com
      10-17-2021, 09:39 PM   #15
januza
60
Drives: X5 45e
I have this installed in my 45e frm Fogiago
      10-18-2021, 10:55 AM   #16
AlpineG05
hi
AlpineG05's Avatar
129
Drives: Alpine White G05
I quite easily removed the intake cover/filter and installed a BMS high-flow intake. In all it took about 30 minutes, didn't damage anything, and the turbos are noticeably louder when they spool up.
Best,
BurgerTuning.com
Their b58 intake will fit. I have it installed on my 22 40i. You'll just need to make a slight mod to the slot of the air sensor. It was a bit too narrow so I just got a file and you'll have to widen it. Other than that, intake fit with no issues. I'll post a photo when I get home.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit
      10-18-2021, 04:30 PM   #17
AlpineG05
hi
AlpineG05's Avatar
129
Bms b58 intake
2022 M Sport G05
cptcolo102.00
      10-21-2021, 04:39 AM   #18
22G0540i
Drives: BMW X5 40i
https://burgertuning.com/products/bm...aa1f&_ss=r
Is this the intake that you purchased?
I have the same vehicle as you and looking to do a JB4 Stage 2
      10-21-2021, 09:05 AM   #19
AlpineG05
hi
AlpineG05's Avatar
129
Yes, that is the correct part. You won't need to use the bracket for install and may need to widen sensor slot.
2022 M Sport G05
Appreciate 2
cptcolo102.00
      10-21-2021, 09:07 AM   #20
22G0540i
Drives: BMW X5 40i
Thank you brother I really appreciate it!
      10-21-2021, 09:38 AM   #21
AlpineG05
hi
AlpineG05's Avatar
129
No problem, let me know if you have any questions on install. It's pretty straight forward though.
2022 M Sport G05
      10-21-2021, 05:20 PM   #22
16sapphireF80
Drives: 07 E92 335i 6mt, 16 F80 M3 DCT
What catless DPs are you using? and who tuned your car? I am picking up my 19 40i this weekend and am looking to modify it asap
xbimmers
