Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications OBD 2 coding adaptor
      03-29-2020, 06:32 AM   #1
Tanzanite G20
Tanzanite
Tanzanite G20's Avatar
9
Drives: 2019 BMW 330i xdrive G20
2019 BMW 330i  [0.00]
Looking to get a OBD 2 coding adaptor for my 2019 G20 330i xdrive just curious what is the best one to buy that's not going to break the bank?
      03-29-2020, 02:26 PM   #2
g20beam
g20beam's Avatar
475
Drives: G20 330i M Sport
2019 BMW  [0.00]
OBDLink MX+
Only one guaranteed to work for everything all modules.
VipinLJ1941.50
      03-29-2020, 02:39 PM   #3
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Originally Posted by g20beam View Post
OBDLink MX+
Agreed. Though if you have an android phone, the lx works as well.
Unicarscan is another recommended adapter that supports all modules.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
g20beam474.50
      03-29-2020, 05:21 PM   #4
Tanzanite G20
Tanzanite
9
Anyone now of where I might be able to buy it in Canada beside amazon or eBay?
      03-31-2020, 09:14 PM   #5
achk
Australia
133
Drives: BMW U11 iX1 Xdrive 30
Anyone has experience with ModBMW Wi-Fi Enet adapter?
https://modbmw.com/shop/wifi-enet/
Thinking of coding with Bimmercode and has an iPhone. I am under the impression from the forum the Wi-Fi adapters are faster than Bluetooth ones.
      03-31-2020, 09:17 PM   #6
VipinLJ
Petrolhead
VipinLJ's Avatar
ModBMW works for G series cars with both Apple and android. And yes. WiFi is significantly faster than Bluetooth. I had the vgate wifi adapter and it was very fast compared to the obdlink lx Bluetooth one which gets on my nerves because of how slow it is.
Current:
achk132.50
      04-01-2020, 08:13 PM   #7
youthsonic
Drives: 2019 330i XDrive
Honestly, I just use an ENET cable, and a USB-C to ethernet adaptor on my iPad - works great, can code every module, and was under $20.
Plus no risk of bluetooth connectivity drops during coding
Appreciate 2
hamzag20557.00
MDG8.50
      04-01-2020, 08:24 PM   #8
VipinLJ
Petrolhead
VipinLJ's Avatar
I’m beating myself up for not going that route!
Current:
      04-02-2020, 09:43 AM   #9
todd92
170
Drives: 05 ZHP, 19 X5 xDrive40i
Yes, and I have a USB adapter for the laptop and a lightning adapter for the iPad/iPhone. No way I'm risking WiFi or Bluetooth while hacking my cars computer.
      04-04-2020, 05:10 AM   #10
MDG
Drives: 19' G20 - 330i, 18' F20 - 120i
I would go this route as well. I have the OBD Link MX+.
It is suitable for use with Bimmercode (a bit slow to connect on some modules).
I can't use the MX+ for xHP Flashtool or BM3, unfortunately. The apps don't connect or detect the MX+ on my phone.
I haven't looked into that issue yet but I do recommend you go the wired route to ensure a steady connection for coding and allow yourself the option to do flashing in the future. I would opt to use a laptop with the ENET cable.
Current Garage:
'19 - G20 330i (Portimao Blue Metallic)
'18 - F20 120i (Alpine White)
      04-07-2020, 12:44 PM   #11
hottroc
45
Drives: BMW 330e
I have an ELM 327 Bluetooth ODBII adapter. Would this work with Esys? Really don't mind if it's slow...happy to wait if it works.
      04-07-2020, 12:58 PM   #12
VipinLJ
Petrolhead
VipinLJ's Avatar
I believe esys needs a wired connection? Like an enet cable
Current:
      04-08-2020, 11:14 AM   #13
PeReZ
Drives: F30 335i
Hi, guys!
ESYS works with modBMW WIFI ENET adapter without any trouble.
ESYS needs ETHERNET connection between the computer and the car and that's exactly what WIFI ENET adapters provide - wireless ethernet.
ELM327 (no matter bluetooth or WI-FI version) is not a compatible with ESYS, since it's using DCAN connection to the car. ELM327, as well as almost all of the bluetooth/wifi dongles, like MX, UniCarScan, vGate and many others, connects to the car through CAN-BUS communication technology, they don't use the high speed ETHERNET (LAN) connectivity which came with F and G series.
Only WIFI ENET adapters (modBMW WIFI ENET, MHD BLACK, uniCHIP) are using the right way to connect to the car. That's why they support times faster speed, compared to the universal adapters like ELM327, Unicarscan, Veepeak, Vgate and etc.
VipinLJ1941.50
      04-08-2020, 01:27 PM   #14
hottroc
45
Drives: BMW 330e
Thanks for the info, I'll get an Enet cable then.
      09-13-2020, 05:42 AM   #15
kanwar144
Drives: G20 BMW 330i
Buying the MHD Wireless OBDII Wifi Flash Adapter
How do you recomend the this one MHD Wireless OBDII Wifi Flash Adapter .
Is it fine ?
      02-06-2021, 10:58 AM   #16
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Is there any other adapter that works in all the modules of a G20?
      02-06-2021, 11:38 AM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
What phone do you use? If you use a Samsung Galaxy or iPhone, I'd recommend getting a wired connection (enet cable and enet to usb c/lightning adapter). Extremely fast and cheap too. And you can access all modules.
Current:
      02-06-2021, 01:09 PM   #18
bquatt
219
Drives: 2020 330xi m-sport
I got the OBDLink CX for like $30 on Amazon. Used it this morning to unlock Sport Plus. Worked great.
jaco_ma28.00
      02-06-2021, 01:23 PM   #19
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Thank you. And also access Body?
In Amazon Spain I only find OBDlink LX (100€) and OBDlink MX (150€).
      02-06-2021, 03:45 PM   #20
VipinLJ
Petrolhead
VipinLJ's Avatar
I have an OBDLink LX. Works fine and you can access all modules. OBDLink CX is made specifically for Bimmercode.
All OBDLink adapters can access all modules.
Current:
jaco_ma28.00
      02-07-2021, 08:55 AM   #21
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Okay. Thank you very much for the information
      02-09-2021, 09:34 AM   #22
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Is there none cheaper and easier to find that also works in all modules?
g20
