F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Painting Calipers, do I need to bleed the brakes?
GetBMWParts
      03-26-2020, 10:13 PM   #1
straightdraw84
26
Drives: 2014 428i xdrive
I've seen how to disassemble the calipers and take them completely off the car on youtube, looks straight forward. The deal is I'll be disconnecting the brake lines as well and sensors. Now I'll cap the brake line, but do they need to be bleed after?
Thanks
      03-26-2020, 10:23 PM   #2
FaRKle!
4017
Drives: 328d Wagon, M2 Comp, i4 eD35
Absolutely.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
sspade2466.00
      03-27-2020, 12:08 AM   #3
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Yes and don't run the brake fluid reservoir dry. You can use a stick or something to depress the pedal against your seat, that way it won't leak much once disconnected.
      03-27-2020, 01:48 AM   #4
straightdraw84
26
Damn, well better safe than sorry
Thanks!
      03-27-2020, 02:33 AM   #5
davidr3
448
Drives: 335i
Or go literally insane with the masking and don't bleed
      03-27-2020, 02:40 AM   #6
johnung
Drives: 2015 BMW 335i x-Drive Auto
Thanks
You don't need to remove calipers. Paint them right on the car (just the visible areas) Use G2USA Caliper Paint. Brush it on and it dries and levels out to a sprayed on finish. It's a two part epoxy like paint that is much harder. Still looks like new 18 months later.
Appreciate 2
Billfitz8244.50
kpgray333.00
      03-27-2020, 02:40 AM   #7
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
You gonna mask the what now?
      03-27-2020, 08:28 AM   #8
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
+1, although I removed mine to change pads, without disconnecting the lines, and while I had them off painted them. I used PlastiKote caliper paint. https://www.plastikote.com/products/...per-Paint.html
I hung the calipers from the springs with a section of coat hanger wire, masked off the undercarriage from over-spray with newspaper. In the two years since I've touched them up without removing them when I had the wheels off to rotate the tires. I used the same paint to do the rotor hubs. This is what they looked like a week ago, five months after the last time I touched them up.
johnung4528.00
      03-27-2020, 08:39 AM   #9
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I painted mine on the car without disconnecting, turned out great! Masked the shit out of it!!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
sspade2466.00
      03-27-2020, 11:26 AM   #10
kpgray
GasCompressor
kpgray's Avatar
333
Drives: 2022 Porsche 911 Cabriolet
+1
I have used this G2 Caliper Kit, it does a great job! My 2014 335i was painted gloss black and retained its glossyness without pealing or chipping for 4 Michigan winters! I just pulled the wheels, masked the discs and other items and go! Just must have all wheels removed and be ready to apply to all calipers at same time. When you get done with first coat it is time to apply second coat to the first caliper. I will do same to new 440i as soon as weather warms up!
2022 Porsche 911 Cabriolet Agate Grey/Black PDK
2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold)
2014 335i M-Sport Black/Beige MPPK/MPE (Totaled)
2013 328i Sport xDrive Imperial Blue/Grey (Sold)
johnung4528.00
      03-27-2020, 04:14 PM   #11
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
i didn't really mask off too much. painted easily enough.
didn't even mask off the clip.
just masked off the rotor.
      03-28-2020, 01:50 PM   #12
davidr3
448
Drives: 335i
If you take your time masking with painters tape, and trashbags you can get just as good as a finish. Might be a little more of a pain getting hard to hit areas but I just bled my brakes a week ago so I don't feel like re bleeding them already when i paint them in two weeks
      03-28-2020, 06:18 PM   #13
Gen13 F36
Gen13 F36's Avatar
I understand you. But the OP was removing/ disassembling his brake calipers off the car hence the comment
      03-28-2020, 09:03 PM   #14
Billfitz
Billfitz's Avatar
He said that he was removing them, true, but if the reason for removing them is to paint them there's no need for it. If he removes the lines then he has to bleed them, adding an unnecessary step.
      03-30-2020, 05:52 PM   #15
straightdraw84
26
I ended up just doing spot touch up for the chipped paint, thought it would be a better use of my time.
Worked out pretty good:
I also removed the black paint from where the rotors touch the rims (paint gets all chipped there and looks awful.
chowser512025.00
f30post
