BMW X5
      03-15-2020, 03:14 PM   #1
OMAHAX5
Drives: 2020 X5 M Sport 40i
IND Painted Rear Reflector Insert
Would love to see a pic posted by a forum member who has installed these on their G05?
This is the only one I can find:
https://cdn.shopify.com/s/files/1/00...g?v=1572128337
      03-15-2020, 05:33 PM   #2
CMBX23
CMBX23's Avatar
Drives: 20' 540i M Sport
2020 540i  [0.00]
Did them myself, very simple and easy to do yourself.
      03-15-2020, 05:41 PM   #3
OMAHAX5
Rear Reflector pic
Thanks much!
How does it look from the corner/angled view and rear side view, if you could be so kind?
      03-15-2020, 08:56 PM   #4
CMBX23
CMBX23's Avatar
2020 540i  [0.00]
Side view
      03-16-2020, 10:59 AM   #5
OMAHAX5
VERY nice! Can't wait to get mine and get them installed!
      03-16-2020, 10:59 AM   #6
OMAHAX5
You should buy my Exhaust tip covers I just posted in that thread?!
      03-16-2020, 12:56 PM   #7
CMBX23
CMBX23's Avatar
2020 540i  [0.00]
Are you talking about the exhaust tips? I plan to get them in the near future. The pic I sent which showed the side view is outdated, I have the shadow line exhaust trim installed now and swapped the original badges for the IND gloss black painted badges. Amazing how such a small thing can affect appearance IMO. Do you have the link to the parts your referring to?
      03-16-2020, 12:58 PM   #8
CMBX23
CMBX23's Avatar
2020 540i  [0.00]
As far as install for the rear reflectors, don't waste your money by having someone else do it. It's extremely simple. Open the trunk both top and bottom. Pull them straight out by hand, no tools needed, then replace with the new ones by just inserting back into the slots. It will take you a total of 2 minutes literally
      03-16-2020, 01:23 PM   #9
OMAHAX5
THANKS for the heads up on the RR install. My M Sport arrived with the Shadowline tips, and I anxiously await the IND painted front and rear reflectors, IND carbon fiber front and rear roundels, IND gloss black rear emblems, and IND Carbon Fiber FLoating wheel cap set to install on my new white X5 :-)
      03-16-2020, 01:36 PM   #10
CMBX23
CMBX23's Avatar
2020 540i  [0.00]
I plan on doing the same carbon fiber roundels front and back, CF floating caps, show some pics when you have them done!
      03-16-2020, 09:34 PM   #11
tellch00
77
Drives: TDI Touareg, 997 Turbo
Anyone know how difficult to install the front reflector?
      03-16-2020, 09:50 PM   #12
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
Here’s DIY guidance
https://g05.bimmerpost.com/forums/sh....php?t=1560241
      03-17-2020, 04:27 PM   #13
130FeetDeep
276
Drives: BMW X5 M50i
Originally Posted by HomeIn2 View Post
I actually just did the front reflector delete from IND. The parts are quality and the improvement to the look of the vehicle is huge.
I strongly suggest buying the rivets and a rivet gun to make the install easy. If not, you will be pulling your hair out. There are two rivets that hold a plastic liner than prohibits you from really getting the space you need to do this right. If you pop those rivets, the work is simple. I bought the rivets and it was an easy job.
      03-17-2020, 07:21 PM   #14
tellch00
77
How is the color match, particularly if anyone has mineral white? that is almost an impossible color to match.
Search this Thread:
Advanced Search
xbimmers
