Right underseat output is low
03-15-2020, 10:52 AM | #1 |
277
Rep 1,575
I just replaced both my underseat with integral audio e90 replacements due to liquid damage. The left side sounds great but the right side is very low on output. I used the two damaged subs to compare any more output even if it was muffed or rsttly but same. I feel like maybe the amp was also damaged but havent diagnosed it yet. If it is, it possible to add an amp and bypass that lack of output for the input of an amplifier?
03-15-2020, 12:29 PM | #2 |
1911
Rep 13,103
You need to know which system you started out with .
There are three systems dependent on which year car an if the car had the pay for it option. Aftermarket speakers will have different specs than stock speakers even if they are the same ohm rating. The head unit has nothing to do with which speaker amp combination you have in almost every year in the US. IN the US only 2010 to 2011.5 came with the ampless base system.Use mdecoder.com to find out which system you have either 676 or 677, 678 lack of these and the date range indicates US ampless tweeter less base system. BMW stereo types http://www.e90post.com/forums/showthread.php?t=352586 http://www.e90post.com/forums/attach...2&d=1266451970 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.e90post.com/forums/showthread.php?t=138949 http://www.e90post.com/forums/attach...1&d=1209780865 http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ http://technicpnp.com/menuDiagrams/d...e90_92_93.html http://www.musicarnw.com/page-2/ http://www.e90post.com/forums/attach...3&d=1169133185 http://www.e90post.com/forums/attach...1&d=1209780605 http://www.e90post.com/forums/showthread.php?t=641323 http://www.e90post.com/forums/attach...4&d=1278871872 http://www.e90post.com/forums/showthread.php?t=343673 |
03-15-2020, 01:01 PM | #3 |
277
Rep 1,575
Sorry. Top hifi. 11' i dont think the headunit is the issue. I did swap woofers out on the right side and still had the same affect. Is it possible the amp is in a protection mode?
03-15-2020, 01:57 PM | #4 |
1911
Rep 13,103
Don't know about what goes on inside Logic 7 amp.
There was one guy on there that replaced an output chip to fix the amp. See last link. You might try swapping speakers from side to side to verify its and amp problem. Also try with all processing off. http://www.bmwlogicseven.com/?p=3837 https://www.bmwgm5.com/Logic7_E90_91_92_93.htm https://www.e90post.com/forums/showthread.php?t=1144129 Better to repair the amp or get another used one as Logic 7 is very difficult to modify . You would still need to fix it anyway as the feed into the amp is Fiber Optic and you would need all channels working to put and amp in between and use speaker outs. Last edited by ctuna; 03-15-2020 at 02:09 PM.. |
