03-08-2020, 03:02 PM | #2 |
166
Rep 1,222
03-08-2020, 08:43 PM | #3 |
2356
Rep 2,964
03-09-2020, 11:14 AM | #4 |
Joint Chiefs of Staff
24095
Rep 190,633
It tricks the ECU to make changes to some parameters (boost, AFR, timing,etc...)
It also connects to Canbus which gives it the ability to add features like boost by gear, boost by RPM, safety failsafe,etc...
03-09-2020, 11:26 AM | #5 |
Petrolhead
1942
Rep 3,521
Can the jb4 work without the obd connection? I read somewhere were they say it can and the obd connection is only for the gauge control thing. Like switching using the built in stalks and speedometer gauge
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
sunglyong25.00 |
03-09-2020, 02:26 PM | #6 |
Rep 23
Yes, I was looking for the figures, or there abouts, of what is changed for each map.
03-09-2020, 02:41 PM | #7 | |
24095
Rep 190,633
Map1: Additive map with peak of 3psi over stock added (91 octane) Map2: Additive map with peak of 4psi over stock added (91-93 octane) Map3: Additive map with peak of 6psi over stock added (93+ octane) Map4: Additive map with peak of 6.5psi over stock added (93+ octane) Map5: Additive map with peak of 6psi over stock added & more aggressive timing profile for higher octane fuel (experimental, 93+ octane, bolt on modifications) Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting Map7: WMI map (boost varies based on WMI additive and map settings) Map8: VALET / Low Boost Map
03-09-2020, 03:27 PM | #8 |
Rep 23
Hi Mike
Thanks for the continued replies. I've seen those figures, but, maybe I'm reading them wrong here, is the 3psi for Map1 just in increase in turbo pressure - no change to timing or anything else? The reason I ask is, I had my old car remapped - reprogrammed ECU. The gearbox spat a tooth shortly after. I'd like to get a better understanding of what is actually changed before I risk the same decision again. I know the B58 in my G29 Z4 M40i can do a lot better though! |
03-11-2020, 10:55 AM | #9 | |
24095
Rep 190,633
03-11-2020, 11:27 AM | #10 | |
166
Rep 1,222
07-17-2020, 11:16 AM | #11 |
68
Rep 450
Does anybody know what's needed for Map 4? Is it ok to run on a stock 2019 m340i? Looking for max power without upgrading anything.. thanks
2014 Black Sapphire Metallic F32 428i xDrive M Sport | Gloss Black Striped Dual Slat Kidney Grills | CF M4 Style Mirror Caps | CF M4 Style Trunk Spoiler | CF Rear Diffuser | Rohana RFX5 Gloss Gold 20" | CF Wrapped Interior | BM3 Stage 2 93 Agg Tune | VRSF Catless Downpipe | Evolution Racewerks Chargepipe | Pheonix Racing Intercooler | K&N Drop In Filter|
07-17-2020, 01:03 PM | #12 |
550
Rep 949
The JB4 includes full diagnostics in the app so record ad JB4 log and post it here and I can tell you if it looks safe or not. The map used has mostly to do with the octane being used and what the factory software is.
07-17-2020, 02:35 PM | #13 |
Petrolhead
1942
Rep 3,521
Will you be kind enough to do that for a measly 330i as well? I’m running map 2 now with ~E30 mix. I wanna know if map 3 is better because sometimes, I feel map 3 is better and at other times, map 2 seems to pull harder. No other mods other than a JB4.
Current:
07-17-2020, 07:01 PM | #16 |
Petrolhead
1942
Rep 3,521
Current:
07-18-2020, 07:00 AM | #17 |
76
Rep 143
Drives: 2020 M340i
Get an account on datazap.me, upload the csv there (make sure it's set to public), and post the link here
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic |
07-18-2020, 12:29 PM | #18 | |
Petrolhead
1942
Rep 3,521
Edit - https://datazap.me/u Let me know if that works Edit 2 - https://datazap.me/u/vipinlj/logging-run?log=0&data=1-4 https://datazap.me/u/vipinlj/logging...log=0&data=1-4
Current:
07-18-2020, 05:37 PM | #19 | |
550
Rep 949
07-18-2020, 06:49 PM | #20 |
Petrolhead
1942
Rep 3,521
Yes sir. Will do. I’ll post that up as soon as I get logs
Current:
07-18-2020, 09:48 PM | #22 |
550
Rep 949
It's been out since 2008 lol. If you want a lot of power and features without having to void warranty with a flash the JB4 is the best way to get there. If you want exhaust pops and bangs you're going to have to bite the bullet and reflash it.
