03-08-2020, 01:07 PM | #1 |
36
Rep 39
Engine block breaks on engine mount point
Hello guys. I have been in this forum for a while as a gust and I learned a lot from you all, and I need some help with this.
I bought an M5 F90 from an auction. I repaired everything (front axial, front bumber, control arm, headlight, ..ect) and the car finally starts. but I notice a vibrations. after some digging unfortunately I found this: The engine block got damaged in the engine mount point. What do you guys think is the best solution. |
03-08-2020, 05:36 PM | #2 |
Soporificist
160
Rep 327
I wish I could offer advice, but I think you'll find that among the enthusiasts on this forum are not a lot of true greasy-knuckled gear heads. I admire you for tackling this project. This car, in optimum condition, is a joy to drive and race, but I wouldn't want to imagine the finesse and trial-and-error required to restore one that's been beaten up as a salvage.
2019 M5 Rhodonite Silver// 2016 M4- retired// 2011 750i- retired// 2004 740i- retired//
2001 740i- retired// 1998 M3- retired |
03-08-2020, 07:35 PM | #3 |
1658
Rep 1,536
Damn that sucks big time.... that's why accident cars are such a big gamble.
I would replace the complete engine, or get a block and transfer everything over. Welding it will be tough, and personally I would not be comfortable owning or operating such a car with a welded mount. |
03-08-2020, 10:00 PM | #4 |
175
Rep 603
Easiest is probably getting them welded on with reinforced welds brackets. New engine block is probably ideal but will be much more involved. As long as the block isn't cracked. it's the mount you can focus on and get a good welder to possibly repair and strengthen.
03-08-2020, 11:25 PM | #5 | |||
36
Rep 39
Do you think welding it will damage or will make some distortion in the block? Im thinking of it. For now im searching and reading about brazing it or using a very strong cold weld like belzona 1111 which I not sure if it will work. The thing is I dont want to do a fix that will make me always think about it while driving or is pushing me back if I want to floor the car. Thanks guys |
03-09-2020, 09:54 AM | #6 |
268
Rep 380
I would second the above suggestion to weld and reinforce - don’t worry about cosmetics on the block as form follows function here. This looks like a major stress transfer point and needs to be really strong. I would also wonder if that let go with the engine movement in an accident then what stress deformation went down through the tranny and transfer case - as a result of the engine movement relative to unibody/ frame... Look closely at those points of contact on other drivetrain areas as well for damage. I’m not a mechanic, just an ex farm kid with an engineering mind. I would assume you have done a full alignment but if not double check that as well - if it is really out of sorts then it might suggest a whole bunch of hidden surprises possible? Best of luck and I hope it works out!
03-09-2020, 09:27 PM | #7 |
12971
Rep 18,716
OP, you got this far already.
I would get a short block and fix it properly so you can have full confidence in driving the car. The engine block is cast aluminum. Once it took a lot of impact, it won't be as good as new. Welding will fix the surface, but any hairline crack that is not visible, may and will cause issue down the line. Again, you got this far already, I won't turn back. Great job btw.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-10-2020, 12:07 PM | #8 |
61
Rep 240
That'll weld up no problem, seen a lot worse in my day 2 day job and a long as it's done buy a professional it'll hold no problem, you could even weld the mount in place for additional strength,
03-11-2020, 03:18 AM | #9 |
359
Rep 658
Drives: 2024 X5MC LCI, 2017 F86 X6M
Sorry to hear that. Since you're close by in Oman i'd advise you to contact Munich Motor Works in Dubai, see if they can give you advise on such a matter. If you can send it to them via recovery and see what they can do.
Good luck!
2009 E71 X6 50i- Azurite Black - Sold
2014 F15 X5 50i - Sophisto Grey - Sold 2023 G70 740i - Oxide Grey - Sold 2017 F86 X6M - Donington Grey 2024 F95 X5M Comp LCI - Isle of Man Green |
03-12-2020, 12:51 PM | #12 | ||||||
36
Rep 39
thanks all. will update you next week |
r33_RGSport12971.00 |
03-12-2020, 01:57 PM | #14 |
36
Rep 39
03-12-2020, 02:14 PM | #15 |
420
Rep 862
Good call on how to proceed. Even if the block itself wasn't obviously cracked you have no way of knowing how stressed or tweaked it actually is. Considering you can see actual damage on the block, replacement is a no brainer.
Wishing you luck and success!
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
03-13-2020, 12:01 AM | #16 |
36
Rep 39
Many thanks bro. The only thing remains in my mind is it going to be as good as stock after opening the engine and changing the block. Is the workshop going to do it perfectly although the car is in one of the best workshops around here that only works in german cars.
03-13-2020, 12:26 AM | #17 | |
420
Rep 862
Getting the right mechanic to do the work will push the odds in your favor. GL!
