Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions M style digital cluster
      03-06-2020, 11:52 PM   #1
Beam330
Beam330's Avatar
29
Drives: 2019 BMW 330i xDrive M Sport
Does anybody have any pictures of the coded M style instrument cluster on the G20?
      03-07-2020, 02:43 AM   #2
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
M style instrument cluster bmw g20.........They inventer something called Google......https://g20.bimmerpost.com/forums/sh...041.....really took me 2,4 sec..........
Beam33029.00
      03-07-2020, 07:52 AM   #3
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
1. Comfort mode
2. Sport mode
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Beam33029.00
      03-09-2020, 01:08 PM   #4
Shinel
142
Drives: 335xi
Wtf is the difference between the original m340i?
      03-09-2020, 01:14 PM   #5
Beam330
Beam330's Avatar
29
From what I've seen the m340i standard cluster looks like the standard 330i cluster with m style fonts... the coded m style cluster resembles the clusters on the M cars and m3
      03-09-2020, 01:15 PM   #6
VipinLJ
Petrolhead
VipinLJ's Avatar
It's the same as the M340i cluster. This is on a 330i.
Edit - Just saw @Beam330's post. I didn't know the M340i had the ordinary cluster.
Current:
      03-11-2020, 08:09 AM   #7
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Beam330 ,
Quite honestly, I have an M340 and my car's cluster looks exactly like the pictures VipinLJ posted. Think the only difference maybe when I start up, the cluster shows the tri-color //M and 340
Having said that, however, I did code the //M in car's iDrive and when I shut things down, the tri-color //M shows up
Hope that helps!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
VipinLJ1941.50
      03-11-2020, 09:33 AM   #8
Beam330
Beam330's Avatar
29
I found some pictures online with the different digital clusters
1. Sport mode on 330i
2. Coded M display
3. Sport mode on m340i
      03-12-2020, 07:22 PM   #9
jstnstr
jstnstr's Avatar
Drives: G20 M340xi
Originally Posted by VipinLJ View Post
1. Comfort mode
2. Sport mode
Hmmm I don't see any difference
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i |
      03-12-2020, 09:14 PM   #10
VipinLJ
Petrolhead
VipinLJ's Avatar
The red markings in the places I’ve circled in the first pic (a sent in the second pic) is the only differentiating factor between the comfort and sport modes.
Another thing I noticed is that the shift lights disappear in the M cluster. So does the tachometer in the HUD. I miss those. Looks like I’ll be going back to the original cluster even though the M cluster is nice.
Current:
      03-25-2020, 11:07 AM   #11
Mr.G20 M340
Mr.G20 M340's Avatar
Drives: 2020 Portimao Blue M340-x
2. Coded M display
2nd one gives some outrun vibes, how do I do this? Have a 2020 m340
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension.
Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe.
      03-28-2020, 01:16 PM   #12
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
I had it and coded it back to normal, You can never tell what mode you are in and you loose some of the map.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      03-28-2020, 02:50 PM   #13
VipinLJ
Petrolhead
VipinLJ's Avatar
Me too. I missed the shift indicator lights and rev counter in the head up display as well. I think the stock is the best as of now. The M display would have been the best if it showed everything the stock cluster showed (mode, gear number when in S, rev counter and shift indicator lights).
Current:
      03-28-2020, 04:26 PM   #14
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
Agree would be great if it still had drive modes, but it looks so good I decided to stick with it! I don’t particularly like the whole cluster changing with different modes, but rather wish it had the small sign in the bottom right corner that said what mode it was in.
      03-28-2020, 04:37 PM   #15
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. That’s what I meant. Some text at the bottom and if they could have kept the rev counter and shift lights, I’d happily code back
Current:
      03-28-2020, 10:25 PM   #16
hamzag20
hamzag20's Avatar
557
Drives: BMW G20 330i, BMW G30 540i
Also, the M cluster needs to be able to show the redline, which it doesn't.
      03-28-2020, 11:17 PM   #17
VipinLJ
Petrolhead
VipinLJ's Avatar
Yup. Which is why, I’m guessing, it doesn’t show the shift lights in the HUD.
Current:
      03-30-2020, 09:56 AM   #18
Beam330
Beam330's Avatar
29
Agree would be great if it still had drive modes, but it looks so good I decided to stick with it! I don't particularly like the whole cluster changing with different modes, but rather wish it had the small sign in the bottom right corner that said what mode it was in.
Yup. That's what I meant. Some text at the bottom and if they could have kept the rev counter and shift lights, I'd happily code back
And g20s don't even go to 8k rpms right? I doubt the display is going to change because it's a generic M display that is non specific to your vehicle
      03-30-2020, 10:52 AM   #19
VipinLJ
Petrolhead
VipinLJ's Avatar
Nope. Redline starts at 6k rpms and rev limiter at around 6.5k rpms.
Current:
      01-22-2021, 05:12 AM   #20
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
any updates on possibility to code mode and shift + "red line"?
      01-27-2021, 11:18 PM   #21
maximking
108
Drives: F10
nobody sees that water temperature is in first photo and second one is oil temp ?
      01-28-2021, 11:08 AM   #22
TTG
TTG's Avatar
Drives: M340
I was going to mention that. That is the MAIN difference. I would much rather have oil temp than water temp.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
g20
