03-05-2020, 10:44 AM | #1 |
381
Rep 821
Drives: 23 G80 M3 6SPD
New tires for 19 x3 m40i recommendations needed
Hey everyone. My x3 has 10k miles and I want to get rid of the run flats. I've narrowed it down to either the Michelin Pilot sport a/s 3 plus and the continental DWS. Does anyone have experiences with either and which is recommended for all season (NY). Also my next question is with a lease return, do I need to return the car with original run flats or can I return with either of the 2 tires listed above?
One more thing, is it recommended to have an alignment done after new tires even though the car has 10k miles? If so, should the dealer perform the alignment or can any performance shop with alignment rack do it? Thanks
Acura RSX-S K24a2 JRSC Swap - SOLD CPO BMW 335i 6MT - SOLD |
03-05-2020, 10:54 AM | #2 |
160
Rep 372
Drives: 2019 X3 M40i
Re: lease return, it has to have run flats
I recently had an alignment done -- dealer wanted $250....had it done at local shop for $99 |
03-05-2020, 11:04 AM | #3 |
808
Rep 1,910
Search, plenty of reading material, example: https://x3.xbimmers.com/forums/showthread.php?t=1674013
03-05-2020, 01:27 PM | #4 | |
Internet Weasel
777
Rep 766
Drives: 2023 X3 M40i
As for which tire, if you do the research on tirerack, I think the DWS tends to handle snow a bit better than the Michelins, and so might be better for you if you think you're going to need that. In Seattle we tend to get snow once a year and my other car wears winters in the winter, so I went with the Michelins. |
03-05-2020, 01:33 PM | #5 | ||
381
Rep 821
03-05-2020, 01:38 PM | #6 | |
Internet Weasel
777
Rep 766
03-06-2020, 06:22 AM | #7 | ||
381
Rep 821
03-06-2020, 08:27 AM | #8 |
Internet Weasel
777
Rep 766
03-06-2020, 08:48 AM | #9 | |
79
Rep 143
The Michelin's might ride harder because they're stiffer. The DWS's are definitely a softer tire from everything I've read, but I've never had the Michelin's on any car so I can't really compare them. I have had the DWS's though, and liked them very much. I will either switch to those, or perhaps the Goodyear Exhilarates, which I've been hearing good things about. |
03-06-2020, 08:59 AM | #10 | |
Rep 6
freshxdough3526.50 |
03-06-2020, 09:42 AM | #11 |
205
Rep 393
I’ve had Conti DWS06’s on my 2020 M40i since new. Love everything about the tires. They ride well and are very quiet. Plenty of grip for an SUV. Tire pressure is a bit critical with these in my opinion. I’m on 20” and running 38 front and 40 rear, cold.
03-06-2020, 10:35 AM | #12 |
1315
Rep 1,065
The Michelin Pilot Sport A/S 3+ are good all-rounders. Great traction in any temp, wet or dry. However their weakness is when on actual snow and ice. Perhaps the Conti DWS 06 are better on snow/ice.
The Bridgestone Duelers RFT aren't terrible. They are mediocre, however they are low-rolling-resistance and get great MPG - about 8-10% better than the Pilot Sport A/S 3+. If that matters to you. |
03-06-2020, 11:52 AM | #13 |
381
Rep 821
I just ordered the Michelin's. I've had that the contis on my previous cars so I'm eager to try these out.
Is it recommended to have an alignment done after swapping the tires?
03-06-2020, 11:58 AM | #14 |
Internet Weasel
777
Rep 766
Not required, but is a good idea WRT preserving the tires and making sure they wear correctly. If your alignment is already good, like you had an alignment a couple months ago, then there's little value. If it's been a while, it's a good idea.
03-06-2020, 12:16 PM | #15 |
381
Rep 821
I'll probably just get the alignment. I've never done the alignment and I purchased in Aug 2019. I rather do it since I've read that many cars come from factory with the alignment out of whack
03-06-2020, 01:53 PM | #16 |
65
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
i've had the Michelin AS3+ on both my 228 RWD and X1 X Drive. I use snow tires on the 228 during the winter because it is RWD but use the AS 3+'s all year on the X1. No problem handling snow on the X1. They are still high performance tires so don't expect 70K miles out of them but they are better than the original RFT's which wore out very quickly.
03-15-2020, 09:15 AM | #17 |
381
Rep 821
Had the Michelin's installed yesterday and alignment done. I was surprised to see that the rear alignment was off from factory. Does anyone have the stock alignment specs for 19 m40i with 19" wheels? Thanks
