03-04-2020, 11:46 AM | #1 |
46
Rep 125
N55 oil filter housing gasket replacement cost in so cal
Hi:
Was wondering what the cost is for an Indy shop to replace oil filter housing gaskets in so cal or Orange County.....recommendations for Indy shops would be great as well... |
03-04-2020, 12:08 PM | #2 |
967
Rep 2,655
DIY $50
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
03-04-2020, 12:20 PM | #3 |
4367
Rep 7,613
I think there is a section of the forum for this. SSR and european auto source come to mind. I never used either, but remember them from when i was searching. I ended up just doing my IC+CP+DP install myself.
03-04-2020, 12:51 PM | #4 |
46
Rep 125
Yeah, was considering doing DIY....have done most things DIY till now...but have moved and no longer have a nice garage to work in....current situation in a very small garage may make it difficult....but still considering DIY unless indy shop can do for a reasonable $$....I know stealer will what over $1000....to replace $30 worth of parts....which is a design flaw anyway, at least to my way of thinking...
03-04-2020, 05:48 PM | #5 | ||
967
Rep 2,655
03-11-2020, 08:25 PM | #7 |
15
Rep 24
Word of advice: should you choose to diy it, get the new o ring seals for the two plastic tubes that hook up to the ofhg. Those two rubber seals can start leaking, especially sfter being takenn apart.
03-12-2020, 01:06 PM | #8 | |
46
Rep 125
Where are you located?.....I am in Irvine......so this is actually on a F13 640i with the N55 engine......it does not look as crammed as it does on a f32.....which is more encouraging to me to attemp diy.....although it looks like one of the intake manifold bolts is not visible but can be feelable.... Also, will a 3/8 drive E10 socket be able to engage the hidden bolt on the oil filter housing......I keep seeing people say you need a 1/4 inch drive socket with a universal joint..... |
03-12-2020, 01:09 PM | #9 | |
15
Rep 24
_das_bae_374.50 |
03-12-2020, 01:42 PM | #10 | |
375
Rep 169
Good luck! |
