03-01-2020, 07:13 PM | #1 |
15
Rep 100
M Performance Brake Kit on my 435i xDrive
Hi guys,
This summer I'm gonna be upgrading my car and would like to put on a set of painted calipers. I'm looking at a full m-performance kit https://www.ecstuning.com/b-genuine-...4112221446kt3/ My only problem is, I heard that some coding has to go into this and I don't want to do it wrong. Currently I have the standard brakes with the 4 piston calipers in front (340x30 rotors), and the 2 piston calipers in the back (300x30 rotors). The kit has the 4 pistons in front and 2 pistons in back as well. Would I still have to do some coding to make this happen? I will also be flushing my brake fluid during this, and will upgrade my brake lines, anyone recommend a specific brand? Thanks, Michael C. |
03-02-2020, 03:35 AM | #2 |
No 55mph
1622
Rep 8,477
Are your rear calipers currently powdercoated in any color?
If not, then they are NOT 2 piston they are 1 piston Bosch calipers and retrofit coding is supposed to be done... These are rear 1 piston: These are rear 2 piston: I use the Exact-Fit Stainless Steel Brake Lines from ECSTuning
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
mgc999115.00 |
03-02-2020, 10:12 PM | #3 | |
15
Rep 100
03-02-2020, 10:33 PM | #4 |
115
Rep 340
You can download esys and codes yourself.. Just search in the coding section
03-02-2020, 10:42 PM | #5 | ||
4541
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
mgc999115.00 |
03-03-2020, 03:27 AM | #6 | |
No 55mph
1622
Rep 8,477
Upgraded to the M4 blue calipers 4 piston fronts/2 piston rears with 370/345 & did NOT code the SPBR brake option That was 2 yrs ago and I have never had any problems with my brakes or brake feel. I'm using Porterfield pads - braking is much better than factory So while some will state you HAVE to code, I agree with others that say it is not always necessary. I don't in any way feel my brakes are unsafe & would definitely have someone code them if I did. Not telling you what to do with yours - just relating my experience... And yes, the coding is for the entire system, not just the fronts or rears individually But coding, if you decide to go that route can be done by:
mgc999115.00 |
03-04-2020, 05:32 PM | #7 |
15
Rep 100
johnung 1QuikWS6 I just spoke to a service supervisor at one of the BMW dealer's nearby and they said that no coding or any work is done on the car when installing their m performance brake kit, so looks like I'm all good. Thank you guys for the help!
johnung4541.00 |
03-06-2020, 04:06 PM | #8 |
490
Rep 1,067
Quick question, I have a 340i with 4-piston calipers up front (stock gray) and 1 piston rear (non-painted). Quetion on Heat Shields.
Looking at RealOEM - it appears the heat shields are all the same regardless of the upgraded calipers in front / rear, however this kit comes with new heat shields? For what? If I owned a 320, 328, or 330? https://www.getbmwparts.com/oem-part...kgUGFnZQ%3D%3D |
mgc999115.00 |
03-06-2020, 04:52 PM | #9 |
15
Rep 100
@CntryClub007 I believe they are actually bigger, but I could be wrong. Just to be safe I'd buy the whole kit. I'm also buying new brake lines, and flushing my brake fluid.
03-06-2020, 09:25 PM | #10 | |
490
Rep 1,067
Anyone know the actual part numbers of the heat shields that come with the "full kit"? I seriously don't think I need them, but really curious as RealOEM.com is often correct. Essentially my 340i is getting the same part number for gear shields with and without the S2NHA option. |
03-06-2020, 11:20 PM | #11 |
15
Rep 100
@CntryClub007 I would just buy the full kit as the new rotors increase in diameter which will probably mean the brake shield needs to be bigger too.
03-07-2020, 12:28 AM | #12 | ||
559
Rep 1,502
Drives: F36 435xd
And the heat shields in the back did not fit. And according to the shop you need to disassemble/change the wheel bearings to get them off. They just fitted the old ones again and it works fine The numbers in the kit are
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
mgc999115.00 |
03-07-2020, 07:39 AM | #13 | |
490
Rep 1,067
https://www.getbmwparts.com/oem-part...kgUGFnZQ%3D%3D But then they fitted the old ones fine? Is the issue the caliper clearance or a bigger shield because of a bigger rotor and protecting the rotor. |
mgc999115.00 |
03-07-2020, 07:43 AM | #14 | ||
559
Rep 1,502
Drives: F36 435xd
Yes according to the shop, the old ones were big enough for the new discs. The holes for fitting in the new ones did not fit the car. If it's because mine is a pre-LCI, that could be the reason. Otherwise I don't know why since I gave Leebmann24 the last 7 digits of my VIN number when ordering the kit
Brgds
mgc999115.00 |
