BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    recent service now carplay issues
      02-27-2020, 07:41 PM   #1
salraf
59
Drives: F90 M5, prior F80 M3, E60 M5
I Recently took my car in for service after I kept getting the 'SOS call System malfunction' message.
It turned out that there was some issue with the backup battery and navigation system which had to be replaced.
When I picked up the car I noticed that my I drive had been updated from system 6 to system 7.
On the way home I discovered that my sirius XM subscription had been deactivated and after several calls to both sirius XM and BMW dealership, the car was returned to the dealership and some type of reprogramming need to do be done for satellite radio to be active once again.
Since then I am unable to get carplay to work correctly. I have deleted the connection both from my phone and from the car on several occasions and when I re-pair, I select the activate card play selection. Bluetooth works fine and I'm able to make calls through my car. However, when pressing the media button, carplay is no longer an option to select.
When I enter the communication menu and select my current phone. I repeatedly get a message that carplay is available and to activate it, I need to delete the phone and re-pair. This, however, never leads to card play being functional.
Any suggestions? Is it something that I need to call the dealership about and something they need to activate seeing it as how they had to reactivate my satellite subscription?
      02-28-2020, 05:51 PM   #2
DannyA
United Kingdom
143
Drives: C8 RS6
What do you mean to went from 6 to 7? Are you referring to the idrive version?
      02-29-2020, 12:42 AM   #3
salraf
59
Yes upgraded from idrive 6 to 7
      02-29-2020, 02:06 AM   #4
Pimpsy
420
Drives: 2019 M5C
idrive 6 upgraded to idrive 7? That can't be right...
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      02-29-2020, 02:22 PM   #5
DannyA
United Kingdom
143
Drives: C8 RS6
ID7 would need new hardware, so defo not 6 to 7.
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
      03-01-2020, 09:39 AM   #6
salraf
59
All I know is that before taking it in idrive version was 6.xxx.xxx and when I got the car back it was 7.xxx.xxx
Because of the SOS issue there was some replacement needed and this is why Sirius xm was no longer working because my ID could not be found this is why I had to take the car back the second time.
      03-01-2020, 12:42 PM   #7
DannyA
United Kingdom
143
Drives: C8 RS6
How did you check the version?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
