BMW M2 Forum > BMW M2 Discussions > Jack point adapters / tire shops
      02-24-2020, 06:47 PM   #1
GiacomoH
Drives: BMW M2
Hello,
It is time for me to replace the tires on my new(ish) to me M2.
This is my first time with a car that requires some sort of special adapter to jack the car up, and will be the first time taking the car some place other than a dealership or specialty Euro mechanic.
Are most tire shops equipped to jack the car up properly? What do you guys do?
      02-24-2020, 07:07 PM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Most places should have a lift which can lift up the car just fine at all 4 points. Sometimes there's a rubber pad or hockey puck as well
      02-24-2020, 07:08 PM   #3
GiacomoH
Drives: BMW M2
Won't that break the plastic if they don't use the square adapter pieces?
      02-24-2020, 08:23 PM   #4
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
The plastic is pretty tough, you are very unlikely to break it putting a flat surface against the bottom of it.
2018 M2 - Daily Driver/Track Car
Motorcity BMWCCA Member
Instagram | YouTube
Appreciate 2
      02-25-2020, 10:26 AM   #5
jessetaylor1
171
Drives: 2018 AW LCI
I crushed one of mine lifting it up using a floor jack with no adapter. I need to buy a new one and an adapter for next time. :
      02-25-2020, 12:10 PM   #6
FaRKle!
4016
Drives: 328d Wagon, M2 Comp, i4 eD35
The plastic edges will usually crumple/fold over a bit if used without adapters, but will still support the vehicle fine. If you want to use adapters on your own later though, that will make it more difficult since they'll be protruding into the pocket.
When my car is going to be serviced elsewhere I usually pre-install the hockey puck adapters I made (they press fit into the cups and will stay in there under driving).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      02-25-2020, 12:15 PM   #7
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
What type of jack did you use? Was it a "racing" style jack with a large flat rubber surface? or a mechanics special kind of jack with the small metal surface?
      02-25-2020, 01:01 PM   #8
243Racing
1448
Drives: M2
I had a hockey puck I used for the Porsches but the first time I tried it on the M it deformed so badly I decided to not use it anymore. YMMV.
      02-25-2020, 01:17 PM   #9
jessetaylor1
171
Drives: 2018 AW LCI
Racing style but, a bit smaller round surface area.
      02-25-2020, 10:06 PM   #10
gandapanda
56
Drives: 18 M2 & 19 Sentra
When a jack is used to lift the car, there is a lot of pressure on the one jacking point. Usually tire shops have rubber pads and lift the whole car using more even weight distribution on each jacking point. I would just stress the shop to be careful with your pride and joy.
S
243Racing1447.50
      02-26-2020, 03:12 AM   #11
Megator
Megator's Avatar
518
Drives: M2 Competition
Just buy 4 of these and ask the indy shop to use them
https://www.ebay.com/itm/Rubber-Jack...cea1fcb5cd85c4
Also new jacking cups are pretty inexpensive
https://www.ebay.com/itm/Car-Part-Ja...8AAOSw~DlcxSEW
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
      02-26-2020, 07:32 AM   #12
243Racing
1448
Drives: M2
S
never thought about it this way, but it makes sense.
      02-26-2020, 01:03 PM   #13
dtmurf
dtmurf's Avatar
482
Drives: M2
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Your mileage may vary and all that but the last time I had my car at the dealer, they put it right up on a lift without any adapters. It was one of those in-ground lifts and it was pretty wide but it just fit between the wheels and they lift the car on all four rectangular adapter points but without the adapters. Nothing got squashed, bent, or deformed.
'17 M2 DCT Long Beach Blue
      02-26-2020, 02:01 PM   #14
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
The jack adapters are a PITA to use IMO, but at least they keep the edges of the jack-point from crushing in over time, and for someone like me that changes wheels and tires a lot, they're a good thing. I wish I could get the thing to sit on top of my jack head without moving.
      02-26-2020, 07:08 PM   #15
GiacomoH
Drives: BMW M2
Well whatever the case I ordered some tires off Tire Rack and will be having a mobile tire service install them. I'll give the guy my jack pad adapter if he doesn't have one.
Interested in seeing how these S007As perform relative to the PSS...
243Racing1447.50
      02-26-2020, 08:09 PM   #16
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
Indeed. I keep a couple on hand for changing wheels. Can echo the sentiment that they are a pain in the ass to use.
Flip that over to my 2015 challenger. That has built in jack pads. Super easy just to slide a jack under and lift it up on any corner.
Instagram | YouTube
      03-01-2020, 10:19 PM   #17
GoneIn4Secs
1287
Drives: BSM F87 LCI (DCT)
Is there a document which shows where the jack points are on the f87?
      03-01-2020, 10:21 PM   #18
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
The user manual included with the car
      03-05-2020, 03:07 PM   #19
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      03-05-2020, 06:31 PM   #20
eeyang92
319
Drives: LBB M2 LCI 6MT
I've used both the jack adapter (with my jack) and rubber blocks (with my quickjack) and have never had any of them deform.
Never tried hockey puck on the jack (unless on the diff support/front support), perhaps the pressure isn't even on the plastic if car tilts and can lead to cracking?
      03-11-2020, 10:30 AM   #21
hshot_rooke
123
Drives: 2017 BMW M2
Dam...I didn't know about these hockey pucks. I've just been jacking my car from the plastic. A little deformity, but so far no issues.
I barely have room to put the jack under the plastic jack points...I wouldn't even be able to use the pucks. Do you have to drive on to some elevated piece of wood to use these pucks if you're in your garage?
      04-02-2020, 11:03 AM   #22
Flange
United Kingdom
111
Drives: M2C
Need to jack mine up as I want to clean the insides of the wheels ( into week 3 of lockdown and I’m bored...)
However, I’d rather use axle stands than just rely on the jack, but once jacked up using the plastic jack points, where do I put the axle stands without damaging anything?
m2
