Bimmerpost
4 Series
Technical Topics Wheels and Tires 19'' HRE FF01 wheels on m340i
      02-21-2020, 05:49 PM   #1
NoTanks52
112
Drives: M340i
I want to buy the HRE FF01 wheels in Anthracite but uncertain where to start with regard to front and rear offsets and tires to pair them with and any other considerations. Anyone have these wheels and/or can offer some advice to help a beginner with the aftermarket wheel buying process?
Just doing some research for now and will likely begin to reach out to wheel shops for more assistance later in the process - Thanks
**Edit: Reached out to HRE and here's what they said for anyone that's wondering:
We unfortunately do not offer a FlowForm fitment for the G20 BMW at this time, but we’ll have fitments for this vehicle in the future. For now, I suggest going with a forged wheel style for your vehicle.
      02-21-2020, 08:51 PM   #2
Gdiddy23
907
Drives: 2020 M340i
2015 BMW F30  [0.00]
We unfortunately do not offer a FlowForm fitment for the G20 BMW at this time, but we'll have fitments for this vehicle in the future. For now, I suggest going with a forged wheel style for your vehicle.
Not super surprised. I reached out to Fitment Industries and they don't even have the vehicle specs and compatible wheels loaded in their system. Even tho this platform has been around for 1+ years, development on it has been painfully slow
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily)
2019 Shelby GT350R (Weekend)
      02-21-2020, 08:52 PM   #3
Gdiddy23
907
Drives: 2020 M340i
2015 BMW F30  [0.00]
I have to manually search by bolt pattern/size on most sites still
      02-22-2020, 01:32 AM   #4
NoTanks52
112
Drives: M340i
What is the bolt pattern and size you are searching for and is there anything else to consider other than that? or should it be a perfect fit so long as the bolt pattern and size are on point?
      02-22-2020, 09:40 AM   #5
Gdiddy23
907
Drives: 2020 M340i
2015 BMW F30  [0.00]
5x112 and you'll have to also verify offsets
      02-22-2020, 10:09 PM   #6
JDUNITNOW
JDUNITNOW's Avatar
Drives: BMW 335I, 750li, X5 G80
That's odd, if you go on www.wheelfront.com there a couple of g20 cars with HRE wheels flow form.
      02-28-2020, 06:53 AM   #7
NoTanks52
112
Drives: M340i
Thank you.. SO how can I tell if the FF01 will fit the m340i after all? I know I need 5 x 112 bolt pattern, but what about offsets?
      02-28-2020, 10:49 AM   #8
chenry
Drives: BMWs
Offset is always the challenge and often times it comes down to personal preference meaning you'll need to decide if you want the wheels to be tucked in, sit flush or poke. Again all three of the aforementioned are purely subjective and/or driven by your need.
"Most" people seem to like things sitting flush or a few mm's tucked in from flush. Once you decide what your end goal is you can start to move on to wheel width and offset.
I know this isn't a complete answer to your question but it's a start....you need to move beyond "will they fit" and start to share what you want.
Hope this helps a bit
ps- I love the HRE FF01 and am really torn between that wheel and the 795M wheel. Similar wheels to my eye but I like the fact that the HRE wheels are wider which would mean I wouldn't have to run spacers (I like a flush look)
      02-28-2020, 10:52 AM   #9
TheBenchmark
59
Drives: 2020 M340i
Hre told me +30 front and +42 rear offset when I ordered my FF10's last week in 20's
      02-28-2020, 12:09 PM   #10
chenry
Drives: BMWs
Update 3.3.20 - I connected with HRE again today and they are always very helpful and patient on the phone - kudos to them for great customer service! Anyhoo this is the second time I've been told by HRE that they do not offer their FF wheels in a 5x112 bolt pattern just yet - so I'm not sure what to say....I guess I wait. It's odd because based on other posts here in the forum it would seem the 5x112 is available but I'm not going to argue with the manufacturer about their own product. So I guess disregard my comments about HRE wheels below specifically for now (remember my first call to them I was told they were available it was my two subsequent calls to them I was told they are not).
Looking forward to updated information from anyone here or HRE when it is available. For now hopefully my sizing logic below helps a bit
Sooooo in that I am in the market as well I figured I'd dig in a bit and share what I found out, this should help.....the FF01's only come in:
-20 x 9: et35
-20 x 9: et25
-20 x 10.5: et35
HRE claims that the 20 x 10.5 et is too aggressive for the rear which means with the 20" only a square setup would work (9" wide Front and Rear).
That said the 19" options are pretty good at
-19 x 8.5: et25
-19 x 9.5: et42
Now we can compare that to a stock 19" 792M wheel with spacers (Like some here are running to get things flush)
-19 x 8: et27 with 15 spacer = et: 12
-19 x8.5: et40 with 13 spacer = et: 27
So punching the aforementioned into a wheel offset calculator, when comparing a oem 792 "flush" setup achieved with spacers vs the HRE 19" offering we get the following:
-Front inner clearance would be: 19mm less
-Front outer position would retract by: 7mm
-Rear inner clearance would be: 28mm less
-Rear outer position would retract by: 2mm
If I were to run this setup (which I may) I would run a 5mm spacer in the front on HRE FF01's which would give me a fitment very close to flush front and rear.
For reference here are the 792M wheels with spacers that I used as a starting point. Remember the HRE's (with a 5mm spacer in front) would be 2mm Front & Rear more tucked (however the overall wheel width would be wider which is always nice) vs these pictures - which would be perfect for me.
Appreciate 4
Gdiddy23906.50
siegester344.50
Rocket455484.00
cheukmc77.00
      02-28-2020, 03:07 PM   #11
TheBenchmark
59
Drives: 2020 M340i
Directly from Jon at HRE before I ordered!
amdmaxx119.00
      02-28-2020, 03:35 PM   #12
chenry
Drives: BMWs
thanks for that!
      03-01-2020, 11:13 PM   #13
NoTanks52
112
Drives: M340i
Originally Posted by chenry View Post
******take all this with a grain of salt until i reconfirm with HRE that they didn't inadvertently confuse the FF01 with the FF10*******you can follow the logic regarding offset etc but i want to make sure the specs are correct on the hre wheels i referenced
I'll update specs on Monday - I called HRE yesterday to update this (as I was driving past them in San Diego) and the sales person actually told me they have no wheels for the G20 - I politely told them they did but he wouldn't budge....sooo I'll try again Monday and get someone else on the line our fitment is obviously something new to them
-20 x 9: et35
-20 x 9: et25
-20 x 10.5: et35
-19 x 8.5: et25
-19 x 9.5: et42
This is incredibly helpful Chenry, thank you!
How does the calculation to achieve a flush look change if we use 19x9 in front? I’m aware these sizes might not be available in the FF01, but trying to wrap my head around these fitment calculations in case I explore other wheels and sizes.
      03-03-2020, 02:41 PM   #14
chenry
Drives: BMWs
Glad it helped some. So the 19x9 in front would extend an additional 1/4" in and a 1/4" out due to it's wider width. If you didn't want the wheel to poke you would want to adjust the offset accordingly. As we go wider it's not only an issue of flush/poke etc...but also clearance on the inner side of the wheel/tire to the struct, fender liners etc...
We have a pretty good idea of how to achieve a flush look on front (based on my calcs, please confirm and or anyone correct me if I'm wrong) it's
19 x 8 = et: 12
Now using a wheel offset calculator you can start to play around with different wheel widths and offset scenarios. This calculator is pretty good but there are many others out there.
https://www.1010tires.com/Tools/Whee...et-Calculator#
ps-remember if you start playing around with spacer scenarios on the calculator adding a spacer decreases the offset :-). (example a wheel with an offset of 40mm running a 15mm has an effective offset of 25mm
again all I try to help where I can but I am not an expert - please please update any of the info here if you find it to be incorrect
      03-31-2020, 10:15 PM   #15
NoTanks52
112
Drives: M340i
Hey guys, I’m looking at vff112 from Vorsteiner now.
They offer 19x8.5 with 20 offset in front
And 19x9.5 with 35 offset in the rear.
I don’t plan to use any spacers.. How do you think this will look? And how far from flush will it be?
      03-31-2020, 10:46 PM   #16
chenry
Drives: BMWs
Hey guys, I'm looking at vff112 from Vorsteiner now.
I don't plan to use any spacers.. How do you think this will look? And how far from flush will it be?
play around with offset calculators to figure out what is acceptable to you. With this thread you get a good idea of what flush is (maybe +\- a few mm) from there you can decide what you want to achieve and then layer in tires
At the end of the day it's very subjective - some like poke - some like stretch - some like flush - some like tuck etc
No right or wrong - just a matter of what you are after - looks? performance? staggered? Square? etc
With more info maybe someone here can help :-)
ps- nice wheel you are looking at
      03-31-2020, 11:47 PM   #17
NoTanks52
112
Drives: M340i
Thanks as always for your help Chenry- how do I figure out tire sizes?
With the front wheel 19x8.5 et 20 and rear 19x9.5 et 35 will the following tires work?
245/35/19 front
265/30/19 rear
      08-12-2020, 06:14 AM   #18
sspdw
71
Drives: bmw m140
245/35/19 front
265/30/19 rear
Rear will be perfect, front i would go for et25, et20 will be too agressive.
I would consider 235 front over 245.
      11-18-2020, 10:36 PM   #19
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
Would these work on a RWD M340i?
Rear
19x9.5 et45
5x112 with 66.56 hub bore
+8mm closer to fender
+18mm closer to the strut
https://www.vividracing.com/hre-ff10...152669632.html
275/35/19
Front
19x9 et 35
+5mm closer to the fender
https://www.vividracing.com/hre-ff10....html?cat=6424
245/40/19
I don't want a "flush" look, but less tucked than stock would be nice. I also like meaty, not stretched tires
      11-19-2020, 12:10 PM   #20
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
Rear
19x9.5 et45
Front
19x9 et 35
I'm a big fan of HRE wheels, but I think the biggest problem to fit it on G20 is center bore, where its 66.56 for HRE and 66.6 for BMW.
      11-21-2020, 05:25 PM   #21
siegester
siegester's Avatar
345
Drives: '20 M340i
From what I can tell online those numbers are usually the same, some places just round up. Looking at the 19x9 et25 that chenry has on his car, they are also listed as having a 66.56 hub bore https://www.vividracing.com/hre-ff10....html?cat=6424
      11-21-2020, 09:46 PM   #22
dodger0629
Drives: G21 M340i Touring
Mine HRE FF10 would be installed when my M340i arrives with the following spec:
F: 20x9 ET25 (245/35/R20)
R: 20x10.5 ET35 (275/30/R20)
funny thing the rep. is really sure they will fit but some of the comments above states they won't (rear wheel is the main concern)...
I did use some rim/wheel websites to do the math on the difference of the 792M (OEM) and FF10 and it does look fine to me...or am I missing anything?
g20
