02-13-2020, 12:01 PM | #1 |
12
Rep 47
coding needed in los angeles
im doing a m sport brake retrofit to my 428i f33 m sport
need this done DSC coding Using Esys 3.23.4 with psdzdata 51.1 1. Connect=>Expert Mode=>Coding=>Read FA=>Save FA 2. Editiors & Viewers=>FA-Editor=>Go to HO-Wort and right click to "Edit", then type (means add) "SPBR" under HO-Wort folder 3. Highlight the FA, "Activate FA" and "Calculate FA" to verify no error is found after adding the SPBR. 4. Check the Vehicle Profile to locate the "aftermarket retrofit" and verify the "SPBR_18_ZOLL_SPORTBRAKE" is added to the folder 5. Write FA to the car. No confirmation window will pop up after saving the FA to the car. So you need to go to next step for verification. 6. Expert Mode=>Coding=>Read FA. You are able to see the SPBR being added to the HO-Wort folder on your car. 7. Read SVT, and locate the "DSC" (File Folder SVT/ECU/DSC), then right click the "DSC" folder and select "Code". Coding would begin immediately. 8. Wait until the coding is finished, and repeat Step 1 to save a copy of the new FA. 9. Unplug the PC from the car. The M-Performance Brake is now enable and enjoy the genuine M-Performance Braking experience. i am in the hollywood walk of fame area |
02-14-2020, 07:23 PM | #2 | |
4488
Rep 10,473
tom @ eas8209.00 |
02-21-2020, 04:24 PM | #5 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
If you have a cable,
I’ll be glad to help you through teamviewer. |
