Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes Lowered and Spacer Installed
      02-10-2020, 02:25 PM   #1
nnnnny
22
Drives: 2021 M340i M Performance
H&R Lowering Springs
H&R Spacer - Front 11mm / Rear 12mm
Appreciate 3
VipinLJ1941.50
amrh296.50
oz555672.00
      02-10-2020, 03:13 PM   #2
john!smith
john!smith's Avatar
230
Drives: M340i XDrive
nice one!
      02-11-2020, 09:10 AM   #3
Cabby
Drives: 2019 X740i
2020 BMW M340xi  [0.00]
2019 BMW X7  [0.00]
Pics from the front and rear please?!
      02-11-2020, 10:31 AM   #4
Chappati21
Chappati21's Avatar
France
8
Drives: BMW M340ix Touring (G21)
Looking good man !
      02-11-2020, 11:28 AM   #5
Burrcold
5297
Drives: 2024 M3 Comp xDrive
Subtle and nice!
      02-11-2020, 03:32 PM   #6
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
more pics?
      02-11-2020, 03:34 PM   #7
DG20
DG20's Avatar
Drives: M340i
Nice! Definitely need some more pics.
Instagram: @dg_g20
      02-13-2020, 12:27 PM   #8
nnnnny
22
2020 BMW 330i
2020 Jaguar F-Pace SVR
2019 Jaguar F-Type R
2019 Land Rover Velar R-Dynamic
2018 Infiniti Q60S
      02-24-2020, 10:22 AM   #9
clipz85
Drives: g20
Could someone tell me what are the spacers for ? can these be installed on stock 330i without spacers ? Regular 18" rims
      02-24-2020, 11:25 AM   #10
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Basically spacers push the wheels out a wee bit and make it look flush with the body line. You can install spacers on any rims depending on if you’re not satisfied with the stock look and want to make it look flushed or pushed out.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-25-2020, 03:39 AM   #11
Chappati21
Chappati21's Avatar
France
8
Looks really nice, great job
Did you keep the original wheel nuts or do you need to buy longer ones ?
      05-06-2020, 06:34 PM   #12
nnnnny
22
Need to buy new wheel nuts. Usually comes with new spacers package.
2020 BMW 330i
2018 Infiniti Q60S
      05-06-2020, 08:57 PM   #13
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
Did you add m sport brakes as well? First pic has normal brakes and the second set is showing blue m sport ones
      06-24-2020, 08:33 PM   #14
nnnnny
22
I have factory M Sport Brake. First picture is showing M Sport Brake, probably just the angle that does not show clearly
I am starting to have noise with the lowering spring. now I am having knocking noise coming from the passenger side. Installer said it's coming from the Spring and Top Plate rubbing. Nothing they can do.
2020 BMW 330i
2018 Infiniti Q60S
      07-04-2020, 08:01 PM   #15
lance666
53
Drives: 320i
Does your rear rub when loaded with passengers?
      08-23-2020, 11:54 AM   #16
nnnnny
22
No Rubbing
2020 BMW 330i
2018 Infiniti Q60S
      08-23-2020, 03:28 PM   #17
TheDudeMan
TheDudeMan's Avatar
Ukraine
252
Drives: 20' 330i & RX 350
Since it's been a few months, how does the car ride? I'm hesitant with these spring because of the amount of drop on factory struts.
      09-07-2020, 06:06 PM   #18
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
Looks fire. Is your car an xDrive?
      09-16-2020, 10:49 PM   #19
ruczko
97
Drives: '20 330xi
Has the noise gone away? Where did you get it installed? I'm about the do the same setup with springs but that has me a bit worried.
      11-25-2020, 01:59 PM   #20
Pom Performance
Pom Performance's Avatar
69
Drives: E90M3 E46M3 X340I 991GT3
Just installed H&R spring on my G20 330I, have same issued. Spring making noise from driver side. Went back to the shop and they retorque the top mount to 120 lbs (most BMW only need 90 lbs). Never hear the knocking noise again
ruczko97.00
      01-18-2021, 11:58 AM   #21
nnnnny
22
Noise did not goes away. Tech had to re-lube all parts but eventually will come back. Tech recommend to change the top mount and bearing that is going to cost $350 parts only per side.
2020 BMW 330i
2018 Infiniti Q60S
      01-19-2021, 12:22 AM   #22
ruczko
97
Drives: '20 330xi
Did you hear the noise all the time when driving or only when moving the steering wheel? I feel like mine is quite faint and I feel it could be the tie rods... according to my advisor my car is not a part of the bulletin that requires a fix.
Did you take it into the BMW dealer as well?
g20
