F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Changing engine mounts, OEM vs Corteco
GetBMWParts
      02-09-2020, 02:30 PM   #1
GOLDENDUSt86
Egypt
23
Drives: f30 320i 2016
Anyone changed engine mounts? I'm thinking of the Corteco, they're half the price. I'm not searching for sportier performance or anything, just mounts that are cheaper than the OEM if they're as good as them,
Here is the link of mine in realoem
https://www.realoem.com/bmw/enUS/par...BMW-320i&mg=22
And part numbers are as follows:
Engine mount, left
12211685941304
Engine mount, right
122116859414
Transmission bearing
22316796617
Total of all four mount , two engine and two transmission are 300$ , the Corteco would cost half on esctuning
      02-09-2020, 03:07 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
They're the same mounts. BMW doesn't make their own, they source them...from Corteco.
      02-09-2020, 05:08 PM   #3
KRS_SN
KRS_SN's Avatar
United Kingdom
13537
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
i changed mounts recently and bought coretco. interestingly they had the bmw emblem in them which someone had tried to partially score off. so one and the same.
      02-10-2020, 03:30 PM   #4
MacklinUSOB
Drives: f30 328i 6MT Sport
Happens a lot with these OEM supplier parts, especially ones that are cast like the mounts or suspension components. My F80 Tension Struts had the M logos buzzed off.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      02-11-2020, 05:07 AM   #5
GOLDENDUSt86
Egypt
23
So, any vibrations, noises?! Are they exactly the same or better/worse? I find the OEM shirt lived
      02-11-2020, 08:07 PM   #6
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
There's literally two other posts below it and above your question that say they are the same part.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
      02-12-2020, 06:38 AM   #7
KRS_SN
KRS_SN's Avatar
United Kingdom
13537
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
i changed springs and shocks at the same time along with mounts and drop links.
The car is silent now bar when it hits sharp bumps(when there is a thunk at the mount area) which is because i have a b8 sporty shock
with stock i would get mount area rattle even on irregular road surfaces like a tapping noise which i don't now.
f30post
