Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions How do I disable Auto Start / Stop on 2020 M340i?
      02-08-2020, 02:32 PM   #1
RLA1999
RLA1999's Avatar
Drives: 2020 BMW M340i
I have been trying everything to turn off the Auto Start / Stop feature of my M340i. My wife has a 2017 X1 which can be easily turned off and the memory keeps it off at all times; even after her car is turned off and on again. When I turn mine off, it stays off until I turn off the car. When I restart the car, the feature is on again. Is there a way to turn it off permanently?
Thanks.
      02-08-2020, 02:39 PM   #2
Burrcold
5213
Drives: 2024 M3 Comp xDrive
Coding it off is the only way.
      02-08-2020, 03:00 PM   #3
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
United Kingdom
443
Drives: BMW G20 330i RWD M Sport
Or sport mode?
Only permanent way is coding
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
gofast182627.50
      02-09-2020, 10:54 AM   #4
themnmd
themnmd's Avatar
Drives: 23 X5MC
I just switch to sport or sport plus every time I drive it. Yes annoying but it's automatic now.
      02-09-2020, 11:54 AM   #5
Burrcold
5213
Same. Get in and press sport individual and drive off.
themnmd1691.00
      02-09-2020, 02:42 PM   #6
2020g20
119
Drives: 2020 330i
Bimmercode.
      02-12-2020, 06:13 PM   #7
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Originally Posted by 2020g20 View Post
Bimmercode.
Use the Bimmercode app and be happy.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      02-28-2020, 03:09 PM   #8
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
ASS Won't Stay Off
Hi,
One of the first things I did on my '14 F30 was to code the ASS Memory so the car wouldn't turn off & on at stop lights.
So when I got my '20 M340, that was one of the first things I coded. Of course, it's in the DME_BACK2 module, which means that if you're coding with E-Sys, you have to make sure the engine is off before you actually code; of course, using Bimmercode, you just have to be in the Diagnostic mode (three quick pushes on the engine on button with no pedals touched).
Well, I have done it multiple times on my car, using either means of coding and I always get the same result:
  • I press the ASS button (turning it off & engaging the orange light)
  • Drive around
  • Shut the car down & as I walk away Comfort Access locks the car
  • When I return, I can see the ASS orange light on
  • Then, if I open either of the front doors, the ASS light goes off (as well as, ASS)
Like I said, I have tried coding it many times. I have even VO coded the DME_BACK2 module and then FDL coded TCM_MSA_Memory from NichtAktiv to Aktiv -- all to no avail
Appreciate any ideas??
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      02-28-2020, 06:48 PM   #9
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
Originally Posted by RSnic View Post
Hi,
  • Drive around
Bimmercode worked for me without any issues.
      03-06-2020, 06:01 PM   #10
RLA1999
RLA1999's Avatar
How is this done? at dealer?
      03-06-2020, 06:02 PM   #11
RLA1999
RLA1999's Avatar
Originally Posted by Tam the Bam View Post
Or sport mode?
I drive in comfort when I got to work and back since it's a long comute so I would like to have it off at all times. Coding is done at the dealer? Or can users do it?
      03-06-2020, 06:03 PM   #12
RLA1999
RLA1999's Avatar
Yeah I know. I have gotten used to turning it off every time now but having to do that plus that light on, is very annoying.
      03-06-2020, 06:04 PM   #13
RLA1999
RLA1999's Avatar
Bimmercode.
Ok. I'll check it out. Thanks.
      03-06-2020, 06:07 PM   #14
RLA1999
RLA1999's Avatar
      03-07-2020, 08:31 AM   #15
themnmd
themnmd's Avatar
Drives: 23 X5MC
Putting in s or sp automatically turns it off
      03-14-2020, 08:08 AM   #16
RLA1999
RLA1999's Avatar
correct. The thing is that I drive to and from work every morning with lots of traffic, so I keep it in comfort, which does not have that automatic function. I put it in Sports mode when there is less traffic and I can step on the gas.
themnmd1691.00
      02-09-2021, 05:05 AM   #17
BamaBlitz
Drives: BMW 330i
What adapter did you use to connect to your car using the Bimmer code app? I downloaded the app but it is asking what adapter I am using to connect to the vehicle. Any help you can give me is greatly appreciated.
      02-10-2021, 06:54 AM   #18
RSnic
RSnic's Avatar
BamaBlitz ,
To use Bimmercode, you have two options to connect to your car:
* Buy an OBD connector that connects to your phone via Bluetooth -- app provides link to their recommended list.
* Buy an EBD cable (OBD plug on one end & LAN plug on other) & a LAN USB-C adapter-- both available on eBay &;Amazon
I've used both & prefer cabled solution as it's considerably faster than Bluetooth & you can use cable if you decide to go to E-Sys for more involved coding
BTW, there's a thread on this sub-forum on this very topic
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
g20
