BMW 2-Series Gran Coupe
BMW 1 Series Forum Second Generation (F40) BMW 1 Series (F40) General Discussion
      02-07-2020, 08:48 AM   #1
orusama
9
Drives: bmw 118i (F40)
Coding an F40
Hi I need some help coding my F40. I searched around don't seem to find enough information on it so I 'm thinking to follow the G20 walkthroughs I found since both seem to have the same arcitecture. Any ideas?
      02-07-2020, 09:08 AM   #2
king YU
king YU's Avatar
8
Drives: G20
I don't know what help you need
      02-08-2020, 03:10 AM   #3
orusama
9
Hi. I just want to know if there is someone that has coded an F40 and what has been done. Or if there are any cheatsheets that I can use to code mine. I tried to use one I found for an F30 but there are many different things.
      03-29-2020, 04:39 AM   #4
MrFoxy
MrFoxy's Avatar
Scotland
377
Drives: F40 M135i. G42 M240i
Zee Coding on Facebook mate...
      03-29-2020, 09:22 AM   #5
JustChris
JustChris's Avatar
17488
Drives: Tesla MYRWD
Be interesting to hear if someone manages to code pops and bangs back into the 2020 build M135is
My car made front page of Bimmerpost
      03-29-2020, 01:59 PM   #6
Spyros E81
Spyros E81's Avatar
Greece
240
Drives: BMW X1 U11 Sdrive 18i
The solution is the Bimmercode app.Buy a compatible adapter to OBD port ( you will find the right adapter to your car in the app) after download the app and then you can find some codes that you can do.
MrFoxy376.50
      03-30-2020, 06:41 AM   #7
MrFoxy
MrFoxy's Avatar
Scotland
377
I'll find out Wed if it'll work, but it'll just be a valve delete.
      03-30-2020, 06:48 AM   #8
MrFoxy
MrFoxy's Avatar
Scotland
377
Just had a look at this app mate, can't see anything about valve deletion.
      03-30-2020, 07:10 AM   #9
knali8
knali8's Avatar
Australia
427
Drives: 2021 X3M Comp
I have ordered an obd adapter to use on my car with bimmercode but it's stuck in Germany
I have used it before on my f30 to code stuff like start-stop off, brake lights flash at slow speeds etc but I don't think it can control the exhaust valve controller. You can code 'sound design' on and off but that's about it.
I think for what you're after.. coding 'pops and bangs' you might need a different coding tool.
On a separate note. I have disconnected my exhaust valves. It's a simple mode. Takes about 5 minutes to do.
MrFoxy376.50
      03-30-2020, 07:14 AM   #10
MrFoxy
MrFoxy's Avatar
Scotland
377
How did you go about disconnecting the valves mate?
      03-30-2020, 07:26 AM   #11
knali8
knali8's Avatar
Australia
427
You need to have the car running, put it in sport mode, check or listen to hear the exhaust value open,
Under the left side of the exhaust outlet there is a connector that controls the valve. You need to disconnect it and that will keep the valve open always.
There are a few YouTube clips that step you through this.
Appreciate 2
MrFoxy376.50
      03-30-2020, 07:37 AM   #12
MrFoxy
MrFoxy's Avatar
Scotland
377
Thanks mate, much appreciated.
Have you done this on your F40?
      03-30-2020, 10:24 AM   #13
EvilDrPorkChop
EvilDrPorkChop's Avatar
United Kingdom
951
Drives: Porsche Cayman
Didn't realise they'd changed out on the 2020 model, what have they done?
      03-30-2020, 11:07 AM   #14
MrFoxy
MrFoxy's Avatar
Scotland
377
Mapped out overrun/pops/bangs mate.
Iv just 2mins disconnected my valve actuator lead in sport mode.... sounds way better now
      03-30-2020, 11:26 AM   #15
EvilDrPorkChop
United Kingdom
951
Guessing this just affected 'Comfort' mode and didn't affect Sport, or is it still not the same as a 2019 model when in Sport?
      03-30-2020, 12:04 PM   #16
MrFoxy
MrFoxy's Avatar
Scotland
377
Wink
When you're in comfort it sounds like your in sport without the harsh MPG, not 100% on Sport mode yet as I haven't driven it yet mate. I'll get out tomorrow morning and give it some.
No pops/bangs, but ill not know till I take it out.
      03-30-2020, 12:39 PM   #17
Stan_Brook
62
Drives: F40 M135i
You could do a similar mod on the F20 series but never felt the need with that car.
This gives me something to do tomorrow AM now! My neighbours are loving the lack of noise on cold starts!
MrFoxy376.50
      03-30-2020, 05:13 PM   #18
knali8
knali8's Avatar
Australia
427
Yep this was my first mod 😁
MrFoxy376.50
      04-03-2020, 04:52 PM   #19
Creedozz
7
Drives: F30 LCI
Does anyone accomplish coding easy entry-exit f40?
      04-04-2020, 03:19 AM   #20
JustChris
JustChris's Avatar
17488
Drives: Tesla MYRWD
What's easy entry exit sorry?
      04-04-2020, 09:24 AM   #21
Creedozz
7
Drives: F30 LCI
If your car has electrical driver seats and memory the function gives you more space to get in-out of the car easier via adjusting the driver seat position back and low, after sitting the driver seat when you push the engine start button it adjusts the seat to your memory position automaticly.
JustChris17487.50
      04-04-2020, 10:20 AM   #22
JustChris
JustChris's Avatar
17488
Drives: Tesla MYRWD
Ah yes of course, thanks.
bmw
